Fuel pump question?
I swapped the 2.7 in my 76 911 for a 3.0 out of a 78. Do I need to change the fuel pump or can I use the 2.7 fuel pump?
1976 911/S/SC/BASTARD
Mid9 Member #12
Old 02-08-2006, 07:32 AM
73.5-77 required 1.7 liter per minute and the SC's ('78) on required 2 liters per minute. It may or may not work at high fuel demand rates (high power operation) depending on the condition of the '76 pump. There are non-Bosch aftermarket pumps that will work and that are significantly less expensive than the OEM pumps.
Old 02-08-2006, 11:01 AM
AZ1977911's Avatar
Jim (or anyone else),
Would you elaborate on the alternatives to OEM if you can?
(I haven't done a search yet)
Greg
Old 02-08-2006, 11:24 AM
