Huh Huh is offline
Speedo repaired but forgot wiring...
I replaced the broken gear on my 150mph speedo but I completely forgot to check the wiring on the back. I know the red fits on the + terminal but I have 3 other wires but two wires are connected together. Do I put the single wire on the 3rd terminal and the connected double wire on the 4th terminal? (no terminal next to the positive) Does anything connect to the negative terminal?
Normally I don't forget but I got stuck on removing the face to get to the gear.
'94 VW Jetta
'85 VW Scirocco
'81 911 SC coupe Euro
'67 VW Bug
Old 02-09-2006, 06:51 PM
Have you looked at the electrical diagrams provided by our host ?
Old 02-09-2006, 09:07 PM
Do a word search under "speedometer electrical" and you should find a wiring diagram and even photos which will answer your question.
Marc Morrison
1964 356C coupe
'89 911 coupe
2008 Honda Accord
2008 Ford Ranger
Old 02-10-2006, 05:09 AM
Huh Huh is offline
nope I didn't. I did a search under speedo. I always do a search first. I guess I will check there.
'94 VW Jetta
'85 VW Scirocco
'67 VW Bug
Old 02-10-2006, 03:36 PM
