How to Remove this interior panel?
How do I remove this leather panel that is on the rear door jamb (the tan leather one)? It looks like it's glued...
Thank you!
-dc
Old 02-10-2006, 10:06 AM
Work in Progress
Rich76_911s's Avatar
Yeah you are correct it is glued on there. It is a otough job to get it off without ripping it too. You might want to try heating it a little to see if it'll come off a little more smoothly.
Rich
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB
-Marine Blue '87 930
Old 02-10-2006, 10:10 AM
Monkey Wrench
Spede's Avatar
I don't even think it's a panel... just leather wrapped over some foam and glued on.
Old 02-10-2006, 10:11 AM
Thanks Rich.
-dc
Old 02-10-2006, 10:12 AM
don911's Avatar
Yep, the leather is just wrapped around that panel. I just recovered mine a couple months ago. If you pull the door seal off in that area, you'll see the edge of the material. There is a really thin piece of foam under the leather that will most likely tear.
Don
24 Cayman GTS - GT Silver
23 Cayman GTS - Arctic Grey - Sold
97 993 Coupe - Arctic/Black - Sold
13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue
Old 02-10-2006, 11:52 AM
Don Plumley's Avatar
To be clear, the panel itself should be a piece of sheet metal. The trim (leather or vinyl), as others have pointed out, is glued on. That's the way it is on my 993 anyway and the way I seem to recall from my '87.
Don Plumley
M235i
Old 02-10-2006, 11:54 AM
don911's Avatar
It was a metal panel on my 87, spot welded on if I recall.
Don
Old 02-10-2006, 12:02 PM
mudman's Avatar
But the sheet metal in this case is not removable.
Try using an old gasket scraper to cut the foam without stretching/tearing the leather piece. If you aren't removing door rubber try to start the removal from the other side(need to remove panel around rear seat belt assy, I think), the leather doesn't go that far under the rubber.
-Jeremy
'73 911 and other cool stuff
Old 02-10-2006, 12:03 PM
