differential output flange bolt torque
What should I torque the differential output flange bolt to? (the single bolt that holds the differential output flange to the trans)
1974 915 trans Thanks, |
20 ft-lbs if it has (if it came with) a washer under it.
31 ft-lbs if it comes without a washer under it. |
| All times are GMT -8. The time now is 11:05 AM. |
