Monkey Wrench
Front Oil Cooler Hood Vent Ideas
I'm looking for some front oil cooler vent ideas to divert air through the front body then up out of the hood.
Here's what I've found on this board... anyone have any other ideas? Can you divert air in the through the front body then out the left and right fender wells?
Insert Tag Line HERE.....
yes you can, ther has been a few people on this board who should chime in. They opened up the inner trunk area, and then vented it out in front of the battery boxes.
p.s. that first green car is awesome!!
Marc |
Cheers, Ryan 1969 911E (historic racer) 911ST replica (tarmac rally) |
Monkey Wrench
" I wonder if it will provide enough flow."
I suspect it's enough. If it doesn't, a couple of additional inline blowers would make short work of any stagnant air in the box (see the white item at the end of the upper vent hose). Sherwood |
Monkey Wrench
Re: Front Oil Cooler Hood Vent Ideas
Concours d'Elegance 2005
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
Friends of Warren
Well there is this...
http://www.elephantracing.com/oilhandling/oilcoolerducting.htm You can't really see much.. I am going to try and look for an RSR set-up picture. A vent in the hood is too much work for me.... but this might just be the ticket. |
Chuck Moreland's step-by-step conversion:
Part 1: http://forums.pelicanparts.com/search.php?action=showresults&searchid=1766171&sortby=lastpost&sortorder=descending Part 2: Center mounted oil cooler project, part 2
Warren & Ron, may you rest in Peace. |
I like the green and gulf blue vents!
Rob Montgomery '88 Blk/Blk 930 ('Lucy') - Not Stock & Not Running |
