Need flywheel help
Installing a new flywheel on a 88 3.2 from pelican (930-102-033-01-M260) and I noticed a small hex bolt behind the starter ring. Does anyone know what this is for? The engine I'm using didn't have a clutch or tranny so I not familiar with this flywheel. Is it for the sensors? Do I need to remove? Using a 915 tranny. This flywheel comes with the starter ring on it.
PJ 78 911sc Targa 70 911T |
She/Her
First of all those teeth on the flywheel are not the starter ring. They are for the speed sensor and that lug with the hex pattern is for the reference sensor. these two sensors attatch to the top right above the flywheel.
Oh on another note, if you are using a 915 tranny, make sure you get the 915 flywheel, not the g50. There is a big difference but they are interchangable.
Gwyneth *she/her 1995 993 Guards Red 1984 911 Targa with a G50 (RIP) |
Thanks beau I finally figured that out. I am using a 915 and have cut out the spots for the speed sensors.
