Heat Exchanger Cleaning
i just removed my heat exchangers, im not sure what they consist of inside but i was wondering if i could put them in my parts washer to get them cleaned up.
brian
*NEW 1969 911t targa soft window option
1967 912 Targa Soft Window
1989 911 GP White Cabriolet
1970 911t
2001 Chevy Silverado 1500
1997 Audi A4 Quattro 2.8
2003 Acura TL Type S
1973 911t 3.0 track car (SOLD)
Old 02-14-2006, 08:28 AM
Bead blast and high temp paint but I'd caustion bead blasting very old heat exchangers. I very carefully bead blasted mine and then painted them with a very high temp silver which I baked in the oven. I could have left them alone but they still looked bad in spots near the intake manifold. Paint has held up very well even on the cross over pipe. Here's a pic.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not.
2012 BMW 528i (wife's)
2007 Toyota FJ (rain and off road days)
Old 02-14-2006, 09:16 AM
randywebb's Avatar
I sure would NOT want to be breathing that solvent - esp. as it heats up...
can you ensure that none gets inside?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 02-14-2006, 09:30 AM
