Question Front Suspension Clicking Noise- Turning
I have an 87 Targa that I bought last summer... when I start driving the car (cold) back up and make several turns to exit my parking structure, I hear a clicking sound up front...
Is this a sway bar bushing or suspension part I can lube?
Car drives well, and was alligned after I bought it...
Thanks in advance!
Patrick
1987 Targa Carrera
Granite Green Metallic
Daily Driver
Pulls in 5th gear-Amazing!
http://www.pelicanparts.com/gallery/speccarrera
Old 02-15-2006, 03:50 PM
Somewhere in the Midwest
MotoSook's Avatar
You'll have to be more specific with noise type and general location.
Old 02-15-2006, 03:52 PM
sorry, a bit too vague-- it's a sharp clicking sound while I do a 3/4 steering rotation-- either direction... hear it maybe 3 or 4 times while making sharp turns. ie. 3/4 turn, 5-10mph, every 5 seconds a click sound is heard... level or graded...
It sounds like it is coming at the wheels, or between the front wheels... if that helps--
1987 Targa Carrera
Daily Driver
Old 02-15-2006, 03:59 PM
PorscheGuy79's Avatar
My best guess would be wheel bearings but those are more like thumps...wait for Souks replay...he literally taught me everything I know.
Matthew
“Sometimes the questions are complicated and the answers are simple.”
Old 02-15-2006, 04:02 PM
MotoSook's Avatar
Have you checked the bearings? With the wheels straight and car parked (of course) try to push and pull transversely (to the car) on top of the tire. There should be a small elastic give due to tire flex, but no popping or clicking, or mechanical motion.
With the tires raised (car on jack, does do the front wheels rotate freely and without noise?
Old 02-15-2006, 04:04 PM
MotoSook's Avatar
LOL..you have learned well Young Jedi...you posted as I was writting my post. LOL!
Old 02-15-2006, 04:07 PM
Now I just gotta get around to doing the rear wheel bearings...
Matthew
Old 02-15-2006, 04:11 PM
Will check out the wheel bearings-- the car came with lowering springs, and suspension is pretty stiff... enjoying the hell out of the it!!! 131K on it.
Thanks for the advice Souk- will check and see-- sounds more like a creaking sound, but who knows until I test and get it up in the air..
1987 Targa Carrera
Daily Driver
Old 02-15-2006, 04:29 PM
1987 Targa Carrera
Daily Driver
Old 02-15-2006, 04:32 PM
87coupe's Avatar
If the wheel bearings check out ok, make sure it's not something simple like the tires rubbing, or a peice of debri tangled up in the suspension components.
ßrandon
Old 02-15-2006, 04:48 PM
thanks, will do... ya, hope it is something benign... the tires do rub once in a while--
1987 Targa Carrera
Daily Driver
Old 02-15-2006, 04:55 PM
ruf-porsche's Avatar
If it was a front wheel drive car I would say to check the CV joints, but since it a PORSCHE 911 I don't think you need to worry about that not unless some numbnut PO decided to convert it to a front wheel drive car
LMAO
Old 02-15-2006, 05:07 PM
Ya, CV's not clicking on my RWD 911 (of course)... would like an AWD 911, but that would be a bit expensive or impossible to transplant from a C4???
hahaha
1987 Targa Carrera
Daily Driver
Old 02-15-2006, 05:16 PM
rnln's Avatar
SpecCarrera ,
sounds similar to mine problem. Still can't find anything yet. If you can find anything, please post.
Thanks.
Fat butt 911, 1987
Old 02-16-2006, 01:22 AM
armandodiaz's Avatar
If you feel it in your steering wheel it may be your bushing and/or rack. I had that problem once, I changed the steering wheel bushing and rebuilt the rack. It's been perfect for 3yrs now.
Armando Diaz
85 911 Carrera - Track car
01 996 Carrera - For Sale http://forums.pelicanparts.com/showthread.php?s=&threadid=327823&highlight=996
87 944na - Old Daily Driver, now 944 CUP
03 Chevy Avalanche- Support Vehicle
70 Olds 442 W30 Conv- Gone but not forgotten
http://www.diazracing.com
adiaz@diazracing.com
Old 02-16-2006, 06:39 AM
Elu Elu is offline
Elu's Avatar
Send a message via Yahoo to Elu
you know, I get that same sound on a cold day when I back my car out of the driveway. It's almost like a rubbing sound, more like a low popping noise. But it only does it when it's cold outside and only when I'm backing out....and once I start driving it it goes away. I don't know what it is.
Come check out my new stuff....you know you want to.
www.myspace.com/elu
Elu - the sensual nature of humanity
Available on Eroica Records
The new album is now available.
Old 02-16-2006, 06:59 AM
She/Her
BeauBlues's Avatar
Lowering springs??? Was your car converted to coilovers? Your 911 should be riding on torsion bars. Sorry to get off topic.
Gwyneth *she/her
1995 993 Guards Red
1984 911 Targa with a G50 (RIP)
Old 02-16-2006, 07:41 AM
PeteBrown's Avatar
I have a similar binding or popping noise when I turn the steering wheel but it does not do it all the time. I noticed this sound after I upgraded my suspension with 22mm front torsion bars, Bilstein sports and turbo tie rods and lowered the car. I thought I was the universal joint(s) on the steering rod due to raising the rack with the spacers. I loosened steering shaft at the univeral near the smugglers box to remove any pressure the raized rack may have put on it. At first the noise was gone but it it has re-appeared occassionally. Any ideas?
Pete Brown
'87 911 Coupe
'20 718 GT4
'25 Aviator
'25 Mach E
Old 02-16-2006, 09:38 AM
Oh ya, forgot! No springs on the 911-- just shocks, struts, torsen and sway bars... I just bought the Dempsey 101 projects book to start learning about the car-- have allot to learn!
Cheers,
Patrick
1987 Targa Carrera
Daily Driver
Old 02-16-2006, 09:49 AM
Pete Brown's post describes the noise perfectly-- like wound up tension-- not sure if last owner swapped out to larger torsion bars or not... it's not a big deal for me- but since I am a new 911 owner, there is a big learning curve-- much different beast than my Spec Miata and WRX...
1987 Targa Carrera
Daily Driver
Old 02-16-2006, 09:57 AM
