-   -   how would you go about adjusting this door (http://forums.pelicanparts.com/porsche-911-technical-forum/266627-how-would-you-go-about-adjusting-door.html)
redcoupe86 02-15-2006 09:58 AM
here is someone elses car i used to show my example. I have exagerated it to show my point. The white outline shows how my door is hanging. the red triangle shows my gap. In reality there is only about a 1/8" difference between the front and back of the door at the lower sill. Am I to assum I will need to use shims to level out the door? The back of the door is at the right heigt, its the front of the door that is off.
http://forums.pelicanparts.com/uploa...1140029924.jpg
Thomas Owen 02-15-2006 10:03 AM
The hinges, where bolted into the pillar, need to have the bolts backed out and allow the door to settle in the front. The hinge bolts have a slot to move around in. You may also have to shim behind the hinge to get the gaps correct.
Good luck -
