Used Parts
Just wondering where you draw the line when it comes to using used parts,for instance my mech tells me not to use pistons and cyls unless new,that sort of thing,what do you all think and how far do you go?
I'll bet your mech will gladly sell you a new set as well!
What does he say about a used crankshaft or cams? If the parts measure in spec according to the spec book, they most certainly can be used....Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
RETIRED
Sometime used parts are all that are available.....if they are within reasonable spec....not Motor Meister spec....no reason NOT to use them.
Your wrench is just trying to pad the bill.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Warren Hall Student
I've bought used P+C that spec'd out as new. No reason not to use them and so I did.
Just make sure you check all the tolerances.
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
I think careful evaluation of parts is where it is at. A part right at the wear limit is not ok, but one with 50-75% of it's life remaining may be ok.
After all, my car contains 100% used parts and seems to run ok. How many used parts are in yours?
