jeff1hughes's Avatar
What are these wires?
On my '86 911, there are two wires by the cruise control vacuum thingy. What are they supposed to be hooked up to? One is brown (ground) One is red. They both have spade connectors on them.
86 Carrera Targa - Garnet Red Metallic
88 928 S4 - Gran Prix White
Old 02-16-2006, 09:39 PM
Friend of Warren
I don't recall having those same wires on my '86 harness. Wonder if they were for the optional rear wiper?
Kurt V
Old 02-17-2006, 07:16 AM
jevvy's Avatar
I was wondering about those 2 wires also - I have them left over after my 3.6 conversion and couldnt work out what they used to be hooked up to.
I was thinking that it might have been the coil since it was mounted in that area.....
'89 3.2/3.6 coupe
Old 02-17-2006, 07:18 AM
I have them also, unhooked. I was thinking wiper, or maybe snorkel brake light, but they didn't have those in 86 did they?
Old 02-17-2006, 08:16 AM
I guess it's time for the test light to come out. I wonder about the wiper. If anybody has a rear wiper on their Carrera, look and see if these wires hook up to it, ok. Thanks. It would probably help all of us out.
Old 02-17-2006, 12:59 PM
abit off center
cgarr's Avatar
Yes they are for the rear wiper, but to make it work you need to run a hot wire from the engine comp fuse box and also a ground..
______________________
Craig
G2Performance
Old 02-17-2006, 01:02 PM
911 carrera 3.2 (1985)
kees's Avatar
Porsche Crest Rear wiper motor
For the rear wiper motor there are 4 wires, brown (ground) , red (always hot) and the other two wires do get power when the ignition is on and the rear wiper switch is on.
Can get a picture in the morning if you want.
Kees.
Old 02-17-2006, 03:00 PM
