Used Parts
Just wondering where you draw the line when it comes to using used parts,for instance my mech tells me not to use pistons and cyls unless new,that sort of thing,what do you all think and how far do you go?
Old 02-16-2006, 05:54 PM
Jeff Alton's Avatar
I'll bet your mech will gladly sell you a new set as well! What does he say about a used crankshaft or cams? If the parts measure in spec according to the spec book, they most certainly can be used....
Cheers
www.turn3autosport.com
Old 02-16-2006, 06:06 PM
RETIRED
Joe Bob's Avatar
Sometime used parts are all that are available.....if they are within reasonable spec....not Motor Meister spec....no reason NOT to use them.
Your wrench is just trying to pad the bill.
2012 ML350 3.0 Turbo Diesel
Old 02-16-2006, 06:10 PM
Warren Hall Student
Bobboloo's Avatar
I've bought used P+C that spec'd out as new. No reason not to use them and so I did.
Just make sure you check all the tolerances.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 02-16-2006, 06:25 PM
HarryD's Avatar
I think careful evaluation of parts is where it is at. A part right at the wear limit is not ok, but one with 50-75% of it's life remaining may be ok.
After all, my car contains 100% used parts and seems to run ok. How many used parts are in yours?
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 02-16-2006, 09:12 PM
