-   -   Brake Gurus - Input needed on 993 conversion (http://forums.pelicanparts.com/porsche-911-technical-forum/267058-brake-gurus-input-needed-993-conversion.html)
Jcon 02-18-2006 03:29 AM
Thanks to the evil influence on this board (Bill V, JeremyD, KTL) I'm going forward with adding 993 calipers to my 3.6 SC. My wife says this is by far the most expensive free website ever created.
I've sourced the calipers/adapters and rotors. I had the holes in the rear calipers welded in and i'll be grinding those down this weekend and redrilling so I can send them off to be rebuilt and powdercoated.
Anyway - I need to order a 23 mm master cylinder.What one do I need. Is there one that will require less work to plumbing than another (Trying to avoid making new hardlines).
Thanks - This won't be the last question.
Jeff
Bill Verburg 02-18-2006 04:26 AM
Turbo Master Cylinder, 911 (1978-89) #930-355-011-03-M4
On this page
Jcon 02-18-2006 04:28 AM
Bill
As always - Thank you!
Jefff
William Miller 06-12-2006 08:50 PM
I'm going down this same path. Is there anything else needed for this Master Cylinder swop in a boosted SC?
Thanks!
Jcon 06-13-2006 03:30 AM
Nope...It was a direct bolt in. Not a bad job either. It took me about 3 hours total.
Jeff
Blanco 06-13-2006 03:56 AM
17" in rims for tt
JeremyD 06-13-2006 05:59 AM
and remove your bias valve...
