add me to Idiot List
It was a nice day, till i decided to clean out the 911. My fire extinguisher had rolled under the seat. I pulled seat forward and placed it back on the hump. Needing to pull all those other items from under the seat, I pushed the Seat back.
I didnt notice that the Crappy Saftey pin had broke (plastic). So, whilst moving the seat back there was a hissing noise and i was temporarily blinded by a white haze. I removed my glasses to clean them, to see the horror before me. I heard a voice in my head, that of Tommy Chong. "Man, i hope the cops dont show up. Do you have any idea what the street value of the interior is man?". Let the cleaning begin http://forums.pelicanparts.com/uploa...1140296329.jpg |
Get it up kwik....stuff be nasty....
Thanks for sharing! :D
BTW, looks like slant nose turbo brake cooler intake in rear wing. What car is that ? |
Its an 88 carrera that was widebodied.
Hey, anyone know what i have to do to use the emergency jack on this? Notice running boards cover the Jack hole. Anyone with experience here. http://forums.pelicanparts.com/uploa...1140298075.jpg |
Hay pmajka, nice car - how about some more pics??
Get a scissor jack and put it in your trunk. Throw the other one away. Do I win the prize?
daaaaaaarrrrk..i like it..especially with the black wheels. :)
ryan |
Come on man...Who is the mfg of those RUF lookin wheels?
that would be ....RUF. 13x17 i back and 11x17 in front
I dont know....til this 911 (which is my first) i have never driven a porsche, and still havent driven another.
it has a 265 HP andial 3.7L. seems to go well, although really comes alive at 4200 RPM. |
Great looking car! I like those rocker panel/running boards.
I once stopped to help a guy stuck on the side of the road, and slid the seat of my pick-up into a can of Fix-A-Flat.
Bad idea. Truck interior, and me, covered in sticky, smelly goo. Really bad idea. |
pmajka,
Unless you take the running board off, otherwise the stock jack is junk. Mine is in the trunk forever. Very nice wheels. |
A friend set off the fire extinguisher in my Dodge truck after I won a tractor pull one time... It was late at night and I had to drive 40 miles home before I could get to the nearest vacuum to clean it up.
what comprises an 'andial 3.7l'...did andial bore the cylinders or were they replaced with larger pistons/cylinders?
ryan |
from andial website
This conversion is based on the 3.8L RSR technology. The RSR has a 76.4mm stroke crankshaft and 102.0mm bore cylinders resulting in a displacement of exactly 3,743.8mm. The cylinder base sealing is done by the use of an O-ring imbedded in the crankcase bore. No copper gasket is used between cylinder and crankcase. The 3.7L engine conversion for the 3.2L differs notably from the 3.8 RSR as follows: The crank has a 74.4mm stroke instead of 76.4mm The housing studs are closer spaced The cylinder heads to cylinders use a different mating pattern For cost reasons, ANDIAL decided to utilize the 74.4mm crankshaft. We are using the original RSR 102.0mm pistons with reduced compression. The shorter 74.4 mm stroke puts the piston 1.0mm below the desired T.D.C. (i.e. 76.4 – 74.4 = 2.0mm total difference or 1.0 mm per side). To compensate for this difference ANDIAL had Carrillo make an RSR connecting rod that is 1.0mm longer, placing the piston in the correct position. A special cylinder was manufactured by Mahle. It has the correct cylinder stud spacing, the proper match for the cylinder heads and is 4.0 mm longer than standard. The cylinder is longer because the case is machined down 4.0mm to provide a solid footing for the larger cylinders. The case is also bored out to 107.0mm to accept the cylinders and an O-ring grove installed. ANDIAL provides this case machining service, or as an alternative, a good machine shop can do the modifications following our instructions. |
pmajka..thanks for posting the andial info. :) sounds like you're saying it really 'comes on cam' around 4k...just a little later than my 2.7 liter, but by then i'm losing sight of the rear of your car i'm guessing.. ;)
ryan |
Blacked RUFs, any chance of getting a pic showing more wheel? I'm thinking blacked RUFs are going on my black 930 in the not-too-distant future...
I'm not typically a lover of boxed rockers on the street, BUT your car looks very well balanced. Very nice and welcome to the group.
Look to the street rod industry for a high quality machined aluminum jack that is both light and collapses to a very low profile. It's so pretty you won't mind it in the trunk, just tie it down for when those 11"rs turn into the corner :) |
Yes I know - try the search :p |
Very handsome car! Please post more pics!
I have seen this before, your not the first, nor the last.
Good reason to buy a Halon fire ext. Thanks for sharing, just laugh and clean it up. Good lesson for all of us. Best luck, Randy Jones 1971 911 "Iris" |
bigrubber..you're seriously going 'all black' on your fuchs? no silver lip at all? i don't think i've ever seen that before..but then again, i'm not in cali.. ;)
ryan |
yeah that's the plan, the PO of my car had the fuch's cromed, so I asked around about getting them back to stock look but according to wheel experts they say I should expect some noticible marking to show after they remove the crome, so this is really whats pushing me more towards the all black look, here is a similar car with all black wheels. Besides, I always wanted all black wheels, the silver lip is really a Jap idea. (nothing against Jap cars, just not on my 911)
http://forums.pelicanparts.com/uploa...1140373857.jpg |
bigrubber..i see. do you have pics of your car you can post (dumb question)? is it a track car like the one pictured or multi-use?
ryan |
Multi Use
On the town http://forums.pelicanparts.com/uploa...1140375486.jpg At the track (not a great pic but you get the idea) http://forums.pelicanparts.com/uploa...1140375601.jpg |
bigrubber...cool...it's gonna look badass. moving through town shot is great!
ryan |
You might consider a Halon unit to replace the dry chemical one....That's the main reason I use Halon (don't like the sticky goo)
| All times are GMT -8. The time now is 04:54 PM. |
