Fresh Air Blower Motor.
Calling from Plymouth, England. Can anyone assist please ?
The Fresh Air Blower Motor on my 1989 3.2 Carrera is playing up insofar as it no longer functions.
Would anyone be able to provide me with a step by step idiots guide to accessing to motor for inspection and testing ?
Thankyou. Tony.
Old 02-17-2006, 01:43 PM
Gordo2's Avatar
From Memory
Best I can do is from memory of removing mine and leaving it out, I didn't photo the job.
-Unsnap felt carpet snaps toward the rear of the trunk (just below the windshield). Pull it back out of the way.
-Remover the black pressed wood/cardboard cover. 3 bolts I think.
-The fan is in the enclosure at the center of the car.
-Remove ducts from both sides.
-Disconnect the heater/vent actuator lines (solid wires with adjustment/retaining bolts holding them in place).
-Unplug the power/speed control electrical connector.
-I think the enclosure is held together with 2 clips. Remove them.
-I think the enclosure splits in half. Remove the upper half.
-Pull out the fan and motor assembly.
Best I can piece together from a project I did a few years back.
Good luck, Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 02-17-2006, 08:35 PM
Air Medal or two
afterburn 549's Avatar
drill hole in front of car ( during iroc bumper install) place vent hose to motor hole ,leave motor out
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 02-18-2006, 08:37 AM
aj88cab's Avatar
I just did this on my '88 3.2 and Gordo has it right, except I think you will have to pull the enclosure out to replace the motor. Although if you can do it in place it will save you a few steps. To pull the entire fan enclosure you also have to remove the mesh intake grille at the cowl and remove two screws that hold the enclosure. Also there is a brace by the brake booster that has to be removed. Actually I think I just unbolted one end and rotated it out of the way. And finally, before you remove the control cables mark them where the clips are so you know where they reinstall.
The whole proceedure is well documented in the Bentley manual. If you are going to do more DIY projects I highly recommend it.
Good Luck
Andrew
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 02-18-2006, 10:09 AM
safe's Avatar
You don't need do disassemble it to test it. You can plug in power in the 4-pin socket under the cardboard cover.
Otherwise Gordo is correct.
Do a search, this has been coverd. Try my user name.
Magnus
Old 02-19-2006, 05:50 AM
Nine9six's Avatar
Re: From Memory
Good luck, Gordo
Gordo,
All that is from memory?!! Apparently you were not a product of the 60's
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 02-19-2006, 07:43 AM
