I need a picture of a 930 starter
I am now wiring up my conversion 3.3 T into the Carrera. I was only using 2 wires for the starter before and nom the harness for the 930 has 3 wires going to it.
1. Main hot lead 2. Yellow with a stripe 3. Solid yellow I am guessing the 3rd is for the cold start injector hot lead? Does anyone have a picture of a 930 starter? |
Well, you don't say what year engine or harness you are using, so this reply may be akin to peeing in the wind. So, picking a year at random, you probably have a big fat black wire from the battery and an a smaller red one from the alternator attached to terminal 30 on the starter. There should be a yellow one attached to terminal 50. The (blue?) striped yellow one should attach to 15a at the starter and go to connector at the cold start valve. Sorry, I have no picture.
Hope this helps, JR |
930 motor and harness, 915 transmission and starter. Is the picture I posted correct?
78 motor and harness, sorry, left that outhttp://forums.pelicanparts.com/uploa...1140366388.jpg
Maybe this diagram will go along with the above comments to help ...
http://www.pelicanparts.com/ultimate...hematic-1s.jpg |
Maybe I need to get a mirror and crawl back under the car, I am thinking the starter said 50 & 16, not 15a. And again after being under this car all day everything is a blur.http://forums.pelicanparts.com/uploa...1140390829.jpg
I hope this thread helps...and the ones embedded within...
http://forums.pelicanparts.com/showthread.php?s=&threadid=186525&highlight=bosch+ starter - Wil |
| All times are GMT -8. The time now is 04:47 PM. |
