-   -   Advice on EFI injector to replace MFI (http://forums.pelicanparts.com/porsche-911-technical-forum/267260-advice-efi-injector-replace-mfi.html)
911pcars 12-07-2006 12:20 AM
Did I miss the source for these injector blocks and their cost?
Sherwood
Nitrometano 12-07-2006 07:36 AM
this project is interesting, I would like to do it to my 72 911T.
BoxsterGT 12-08-2006 12:58 PM
:confused:
Details, details.............
How is it running?
What injectors did you use?
Did you find ones w a long nose to reach the port wall?
Any driveabiliy problems?
Please keep us advised.
Len
Fdalgas911T 12-15-2006 07:51 AM
Yes, the EFI injectors are snugged into the injector holes. I am in the break-in period with only a few hundred miles on the engine. The car is certainly driveable however I am reserving judgement to recommend this to others at this point. The car idles well, accelerates well, feels good overall. I am currently working out some gurgling and backfiring issues that sometimes occur during deceleration and have made significant progress thus far. These are minor issues at present. It is just a matter of logging, evaluating and tweaking the Motec unit fuel and ignition settings/talbes/charts/graphs. While this process is easy to perform, it is tedious and takes time. My current plan is to perform the final tuning on the dyno using an experienced engine tuner when the engine is fully broken in. I am seeking benchmark comparison information and would like to drive other similiar 911s so I can evaluate. At present, I'm confident current minor issues can be tuned away. Would appreciate any dyno charts or comment from any pelicans with experience tuning unique engine configurations comparable with mine.
CliffBrown 12-15-2006 09:22 AM
Do you have a switch in the system to stop fuel flow with a closed throttle and the RPM above 1,500?
Thanks for doing the R & D work.
Keep up the reporting, a great read.
beepbeep 12-15-2006 10:08 AM
Zero the tables with high vacuum above 1200 RPM, thus enabling fuel cutoff on deccel. It will take care of popping.
lateapex911 12-16-2006 10:57 AM
I kinda like gurgling and snapping on the overrun, LOL..;)
beepbeep 12-16-2006 11:30 AM
It fouls the plugs and dilutes the oil. Also, it might damage ze auspuff.
John S 11-07-2007 07:20 PM
Hi Fdelgas911T, I as following your efi conversion with great interest. Keen to know how it is going. Thanks for sharing so far....
Lukesportsman 11-25-2007 05:55 PM
Yes, many of us are looking for updates.
1glengeorge 11-26-2007 09:39 AM
enrolling in this class.
kenikh 11-26-2007 09:23 PM
Been wanting to do this for years. Glad to see someone got of their a$$ and did it. Kudos.
70SWT 11-27-2007 05:51 AM
+1 to these questions...
Originally Posted by BoxsterGT (Post 2972426)
:confused:
1972_911T 01-08-2008 10:54 AM
Any updates on this? did you manage to get the engine tuned ok? did the injectors survive placement in the heads? I would like to do this on my 3.0 and have my heads off ready so now would be the time for me to do the machining.
This would be really cool if it worked out.
Regards Steve
shbop 01-25-2008 07:04 PM
Just wanted to bump this for an update. Any new information on how your car is running?
Danny_Ocean 01-30-2008 06:16 PM
Here is the last post by "Fdalgas911T" (2/7/07)...
http://forums.pelicanparts.com/3090059-post34.html
Perhaps someone should send him a PM?
davidbir 09-09-2009 02:57 PM
This thread died while still educating a lot of people--any updates?
Anybody else do this?SmileWavy
kenikh 10-26-2009 12:37 PM
Hoping another bump will get a summary. Fdalgas911T was last on the forum May '09... :(
