82 911 SC fuel Pressures Are these in Spec w/ Bentley?
I am waiting on my Bentley manual. My car when started cold runs a little rough. It usually doesn't stall (it has once or twice) but doesn't run smooth either. I checked my fuel pressures today and I was wondering if someone could check their Bentley manual and post the specs. Here are my fuel pressures:
Cold Control : 2.9 Bar Warm Control : 4.1 Bar Control Pressure : 4.75 Bar Any info would be appreciated. Thanks. |
Per the graph in Bentley's, 2.9 bar with engine cold and running would be right for about 28-34c ambient. Engine warm and running regardless of outside temp should be 3.4-3.8 bar. Engine off and pump running should be 4.5 - 5.2 bar.
