-   -   Where to acquire steering extension hub? (http://forums.pelicanparts.com/porsche-911-technical-forum/267322-where-acquire-steering-extension-hub.html)
SLO-BOB 02-19-2006 03:41 PM
I did a search and found that there was a factory "1" hub extension available. I'm wondering if there is a "2" hub? Actually, I don't know where to get either so any help would be appreciated.
javadog 02-19-2006 04:35 PM
The factory one comes attached to the steering wheel. They didn't offer a 2" version. Aftermarket wheels, such as Momo, can be extended with separate pieces but these are also more like 1" in depth. You might want to find a deeper-dished wheel. One word of caution however; the more you extend the steering wheel away from the hub, the harder it will be for you to reach the stalks to the side of the wheel with your fingers. With the standard extended-hub factory wheels, this aspect is noticeable and a little annoying. I personally wouldn't want a greater extension. You can usually find these wheels used on Ebay, or in various classified ads, such as on Pelican.
JR
trak ratt 02-19-2006 06:32 PM
Quick release hubs will give you about an additional 2”s. Can be deactivated and removed if you get a bolt on, not weld on. Other issues is horn operation.
Jack Olsen 02-19-2006 07:07 PM
What steering wheel are you trying to space? My guess is that it's not the stock one.
A Teknik quick-release and an offset spacer moved my 930S wheel almost 2 inches closer to the driver. The bonus with the quick release is that it also functions as a hard-to-beat theft deterrent. The offset spacer increases legroom, improves the sightline for the gauges, and makes centering the wheel more intuitive.
My horn works fine with it, too.
SLO-BOB 02-19-2006 07:33 PM
Actually it is the stock 77 steering wheel. I may have to change that.
Offset spacer? Do you have a pic of that with the wheel on?
Jim Garfield 02-20-2006 01:55 PM
Jack, where did you find the offset spacer? The MOMO sellers that I have questioned don't have it. I'm trying to find one that will work with a Prototipo and MOMO adapter.
Zeke 10-23-2006 07:52 PM
I'm bring this back to find the offest spacer, too.
SuperClyde 10-23-2006 08:09 PM
Is there an offset spacer for Momo steering wheels? I've seen them for the 930 steering wheels but not for any others...
Zeke 10-23-2006 08:51 PM
I guess if anyone did have it, it would be this guy:
http://stores.ebay.com/Crowders-Customizing_Steering-Wheel-Hub-Adapters_W0QQcolZ4QQdirZ1QQfsubZ17QQftidZ2QQtZkm
No offset there.
pjv911 10-23-2006 09:12 PM
I have a stock 1" spacer for the 3 spoke wheel. With hardware included I would sell for $50.00 + shipping.
Kurt Williams
