vizail's Avatar
915 Tranny Ratle
It seems that a ratle is coming from my915/ 1982 /911 Tranny.
What section of the transmition moves all the time while that tranny is in neutral.
Tell me your experience in dealing with this kind of ratles.
I heard about some bearings that tend to wear out on this area.
All the Info. is really apreciated..!
Vic
Old 02-20-2006, 05:22 AM
Blanco's Avatar
rubber center clutch?
1982 Porsche 911SC Coupe - Factory Short Shift |7:31 R&P in AL case | Toyo RA1 Tires | Corbeau TRS seats | M&K 2 in 2 out muffler
Old 02-20-2006, 05:30 AM
vizail's Avatar
Blanco
Have New clutch disc, center, trust bearing & Presure plate. The sound comes from inside the tranny
Vic
Old 02-20-2006, 05:33 AM
does the rattle continue when you press the clutch down?
On the input shaft youve got a combo of sliding sleeve and free wheeling gears. I would be suprised if you had a problem with gears/syncros that you didnt know about when you were driving in that/a gear.
How was the box before the change of clutch?
Old 02-20-2006, 06:00 AM
vizail's Avatar
It Stays the same.
I'm beginning to suspect that some roller bearings are defective. Furdermore I have some issues with the syncros. I have to be very careful when downshifting from 5th to 4th sometimes I hit the riverse gear anf grinds a bit. I think is a bout time I rebuilt the tranny. The previous owner beleives he had a Hot Rod and he did't care much for the tranny.
Vic
Old 02-20-2006, 03:04 PM
vizail's Avatar
Hey Blanco ..,there is no rubber center in this tranny
Vic
Old 02-20-2006, 03:05 PM
