-   -   Help!!! How do I find out what this Engine # Means (http://forums.pelicanparts.com/porsche-911-technical-forum/267420-help-how-do-i-find-out-what-engine-means.html)
louielargo 02-20-2006 09:19 AM
I have what I think is a 1971 911E Euro Model. It looks like many parts have been updated.
The Engine number is 6551315
The Engine Type is 911/44
My reasearch tells me that it is from a 1975 911S, but I don't know what the type code means.
I would greatly appreciate any input, Thanks in advance.
Best Regards, Louie
tonythetarga 02-20-2006 09:28 AM
according to Bruce Anderson's book the 911/44 is a 1975 2.7 911S for California. specs same as 911/42 but with reduced power. 8.5:1 compression ratio with 160 hp @ 5800 rpm and 162 lb/ft torque @ 4000 rpm
the 911/42 is 175 hp @5800rpm and 175 lb/ft @4000rpm
post the VIN so we can determine the year/model of the tub.
mmastro 02-20-2006 09:30 AM
According to Bruce's bible: 911/44
2.7 911 S engine for California (reduced power)
8.5:1 160HP @ 5800 RPM
167 Lb/Ft @ 4000 RPM
Cheers,
edit; Dang, 2 minutes late...;)
klaucke 02-20-2006 09:32 AM
Yes, the engine type code is congruent w/ a 1975 911S motor for delivery to California.
tonythetarga 02-20-2006 09:44 AM
I believe a 1971 911E serial number should look something like this:
911120XXXX
broken down it is:
model = 911
year =1 for 1971
engine type =2 for 911E, 1 for 911T and 3 for 911S
Body version = 0 =coupe; 1 =targa; 2 = Karmann coupe
Sequential serial number = xxxx
total is 10 digits for a 1971 model car
mmastro 02-20-2006 09:51 AM
[i]
post the VIN so we can determine the year/model of the tub. [/B]
"It's a 1971E with Euro gauges. The VIN is 9111210433" (From a previous post)
911=911 model
1= 1971 model year
2= 911 E engine type
1=Targa body version
0433= sequential serial number
tonythetarga 02-20-2006 09:57 AM
As far as I can tell the only way to know for sure if the car was originally a Euro (at least in the earlier cars) is to go by original engine #, which in this case is no longer available.
Porsche may be able to sell you a Certificate of Authenticity and tell you original destination. I think they charge about $75 or 100 bucks for that.
Joe Bob 02-20-2006 11:01 AM
Which are notoriously inaccurate....
louielargo 02-20-2006 01:33 PM
Additional Engine Info
Thanks Tony, Mike, J.K. !!!
I really appreciate the info!!!
It is a very unusual project that I just bought.
The VIN # is 911 121 0433
Blue Plates 833WEZ
The Color Code is 1412-L (May Have been Special Order)
It has a 1980 911SC Front Suspension
911S front Bumper
The 1975 911S Engine has been rebuilt with MFI not CIS, the MFI t-Body has a Part Number of 911.101.312.1R (Possibly to do an RS Clone).
It has an Alluminum Flywheel with 3 notches???
What do you guys think?
Thanks, Louie
louielargo 02-20-2006 01:46 PM
Pics...
http://forums.pelicanparts.com/uploa...1140471869.jpg http://forums.pelicanparts.com/uploa...1140471953.jpg http://forums.pelicanparts.com/uploa...1140471990.jpg
