LM-1 user's...not a permanent install but..
how do U run the cabling into the cabin? i've seen pix of the wiring running outside the car but i'm concerned with the tire catching it. tia.
I drilled a hole on the vertical panel just to the left of the center tunnel. Basicly about 3" to the left of the left ebrake cable where it enters the tunnel.
I have also used masking tape to hold temporary test equip to the outside of the car. It works great and holds good. Dean |
I run it up past the tin through the decklid and in the 1\4 window..
| All times are GMT -8. The time now is 09:44 AM. |
