wiring diagram request for power mirrors
I am trying to put a non-heated power mirror onto a car that originally had a heated power mirror. I 'm not sure what year the car was that the non-heated mirror is from, probably an eighties car, but the car it is being installed on is an 89 cabriolet. The wires coming out of the non-heated mirror are Black, Brown, Blue, White, and gray with green markings. The wires coming out of the heated mirror are Gray with a Green stripe, Green, White with a Green stripe, Black, White with a Brown Stripe, and two Brown wires that are connected to the same terminal. In addition, the solid Green wire is jumped by a White and Green wire to the terminal with the White and Green wire. The two sets of wiring I have described are both coming out of the plugs at the ends of the wiring harnesses that plug into the harnesses inside of the mirrors. I have deduced which wires control the heater portion of the mirror, but I do not know which of the other wires is a ground for the motor, and which wires control which direction. As always, any help is greatly appreciated - Thanks in advance
Old 02-20-2006, 07:35 PM
bump for help
Old 02-21-2006, 10:15 AM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
Here's the Bentley diagram for 86-89
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 02-21-2006, 10:41 AM
I thought that all power door mirrors glasses were heated. There is a difference between early and late old-style mirrors, the glass fixing, motor and wiring was changed about 87.
An early 80's glass won't fit a later 87-92 mirror and the wiring has to be correctly changed as the plug and socket are different.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 02-21-2006, 10:53 AM
from my understanding, 87-89 had a different setup than the earlier ones
Old 02-21-2006, 11:35 AM
There are color code variations within years. I think Porsche did this to F with our heads.
So, going by color code is a guessing game. Best first step is to trace and document where each wire goes within the mirror.
Warren & Ron, may you rest in Peace.
Old 02-21-2006, 11:46 AM
Anyone have a diagram for pre- 86?
Old 02-21-2006, 12:18 PM
UFLYICU
ZOA NOM's Avatar
prc-racing.com
Old 02-21-2006, 12:33 PM
For additional reference:
Actual mirror wire color coding from driver side 1985 Carrera.
Followed by Wiring chart from an SC.
Old 02-21-2006, 01:02 PM
UFLYICU
ZOA NOM's Avatar
Damn, Michael, if you can't figure it out now, there's just no hope. Nice work, Rick
prc-racing.com
Old 02-21-2006, 01:55 PM
Likewise.
I have a bit more but don't want to flood the board with too much info.
Old 02-21-2006, 02:01 PM
