Adel clamp source
can any one give me a source for adel clamps? need to replace my oil cooler front fender oil line ones...1"+& 2"+
thanks km |
Porsche sells the official mechanical clamps that run along the rocker panel. For other areas, Adel clamps can be sourced from any number of industrial hardware suppliers such as McMaster & Carr, large electrical supply houses or most fastener sources.
Sherwood |
Txi Aviation ... 8350 Denton Drive, Dallas TX ...
Or, any of the hotrod shops in the area ... |
Be sure to get ones with the rubber isolator rated for at least 250F. Regular rubber isolators in clamps will quickly deteriorate from the heat of the oil lines.
Go to your closest general aviation airport and ask a aircraft mechanic if you could buy some. They come in a variety of sizes
check out mcmaster.com they have more to choose from than any place I've seen.
also, aircraftspruce.com Doug |
I forgot all about aircraftspruce.
www.aircraftspruce.com (california and georgia)
www.wicksaircraft.com (illinois) www.wagaero.com (wisconsin) Adel clamps and other fun stuff can be ord'd from any of the above. |
| All times are GMT -8. The time now is 01:54 PM. |
