87 cab alignment question
As I've mentioned in earlier posts, it's time for tires. Took it to the tire shop (NTB) recommended by local Porshe garage, and they pointed out lots of wear on the inside of the front tires, worse on the passenger side than the driver's. They suggested an alignment. As this is my first Porsche, I want to make sure they do the right job. Is anyone familiar with NTB and their abilities? They quoted $129 for the job. Should I assume they know the proper specs?
Y'all have been great with my past queries - appreciate all of the help.
I'll call the Porsche garage tomorrow and ask if they do alignments there, and get their recommendation, but I thought I'd ask here, as well.
Thanks!
Bruce
1987 Carrera cab
Old 02-23-2006, 04:31 PM
Send a message via ICQ to Terrh
I've neverr paid more than $30 for an alignment, but I've never had a porsche 911 aligned either.
my RX7 shouldn't be significantly easier though, not 1/4 of the price easier anyways.
I'd suggest getting a second opinion!
Old 02-23-2006, 04:55 PM
thanks - I thought that it sounded a bit high, too, especially since they are replacing all four tires at the same time. I'll see what the garage quotes tomorrow, if they do alignments (they don't do tires), and ask around some with some local PCA'ers to find out who they use.
Of course, this is the first work I've had to have done, so I'm not aware of costs. That's why this forum is great!
Bruce
1987 Carrera cab
Old 02-23-2006, 05:10 PM
All the alignment specs are preprogrammed in the alignment machine software, so they have the factory specs of all the cars at their disposal.
The question is, can you expect to have it aligned to spec if the car lowered below factory spec as most 911's are? Probably not.
Cheers,
Joe
Old 02-23-2006, 10:58 PM
jdowty3's Avatar
I had 2 front end alignments done in Dallas and $129 is about right for a 911. I think a 4 wheel alignment was around $160. You can request alignment specs designed for more sport driving (DE, mild track, aggressive street) rather than OEM specs.
Jim Dowty
97 911 Coupe (Forest Green metalic, sunroof, leather)
PCA RSR region Insurance chair and Board member
Gruppe B #309
Old 02-24-2006, 04:42 AM
not sharp's Avatar
Bruce;
Had my cab done yesterday, $41.29.
Oh, front align only.
84 Carrera Cab - ROW
Thanks to this Tech forum!!!!!!!!!
Tranny rebuilt etc..
Fresh Konis,
Lowered front,,
R&R injectors,
Wonged,
Valve Adjust,
Electrical solutions,
Next;
Lower rear, Corner balance
Old 02-24-2006, 04:45 AM
That might be his problem.
Old 02-24-2006, 09:34 AM
Having only had the car since mid December, I don't know how the PO had the car aligned. Dumb question - is there a place I can look, such as the owner's manual, that lists the various specs? Armed with that information, I'll be able to identify how it is set, and have them make the appropriate adjustments based on how I am going to drive the car. BTW, the current tires are almost 7 years old, so this may have been going on for a while.
Bruce
1987 Carrera cab
Old 02-24-2006, 09:40 AM
MBruns for President
JeremyD's Avatar
negative camber - to make bigger tires fit can cause inside tire wear
Old 02-24-2006, 09:55 AM
BReyes's Avatar
I would have a performance shop do the alignment/lower to Euro specs/corner balance it to set it up with more negative camber, and just right ride height. That way it will handle best. You are the right course, taking to people and corroborating.
Good luck.
Bernard
Old 02-24-2006, 10:03 AM
