-   -   3.6 conversion guys - where have you mounted your coils? (http://forums.pelicanparts.com/porsche-911-technical-forum/268220-3-6-conversion-guys-where-have-you-mounted-your-coils.html)
Joeaksa 03-01-2006 04:04 PM
My coils are mounted like Ingo's. Would not want them on the engine due to vibration IMHO.
JoeA
William Miller 03-01-2006 06:00 PM
Originally posted by ischmitz
I used a stock relay socket from a 964. It was not the DME relay but for something else. I opened the plastic base and soldered new leads to it. The capacitor should have been in the donor car. It sits behind the metal plate in the black box in the engine compartment.
On the capacitor, I'll have to look, but if it was there, I got it!
I pulled a few extra relay sockets from the car, but the terminal numbers didn't match what you have in your diagram (#1,2,3...)
The relay itself has a little diagram on it with the terminal designations (30,87a ....) I assume I should not worry about what's on the connector, but follow the designations. Right?
Thanks again for all your help!
Things are comming along.
NoEardGoat 12-21-2009 09:55 PM
How does one mount the coils like Ingo has them mounted? I have the fuel accumulator and fuel filter in the way on my SC? Can this be moved?
jm58 12-22-2009 03:59 AM
Here is my 3.6 coil place:
[img=http://img264.imagevenue.com/loc175/th_82915_DSC06503_122_175lo.JPG]
DW SD 12-22-2009 07:05 AM
Note the rubber isolators between coils and the body and the fuel filter and the body.
http://forums.pelicanparts.com/uploa...1261494250.jpg
Joeaksa 12-22-2009 07:52 AM
DW,
Very nice looking and like your idea on the photo!
NoEardGoat 12-22-2009 07:58 AM
Is eliminating the fuel accumulator ok to do for a 964 motor?
My 911's factory rear fuse box and filter setup looks like the one pictured on timmin's website. http://instant-g.com/Cars/BlauCarrera/BlauCOil.jpg
I have the 964's fuse box and want to use it, but the coils won't fit with the fuel filter and accumulator in their stock location. The wiring harness isn't long enough to mount the coils with the motor like 993 and I prefer to mount them on the fender wall. Ideas?
DW SD 12-22-2009 08:57 AM
Originally Posted by Joeaksa (Post 5083894)
DW,
thanks!
It helped me keep the wires in the harness connector straight.
It is indeed interesting when these threads are resurrected years later. The photos on my computer are nearly as old as the thread. Haven't seen them in moons.
Doug
midnight911 12-22-2009 09:54 AM
mine looks similar to jevvy's pic.
