LinkBack | Thread Tools | Rate Thread |
Can you tell if a top-end rebuild had been done by visual inspection?
Found an 82 sc with 130Kmi. Good leakdown of %8 -%6 and solid compression of 155 across all 6 cylinders. Last valve adjustment 5k ago had no broken head studs. The car has a limited service history. Since it’s an SC I am worried about the head studs failing soon. The PPI appears good, is it possible this car had a top-end done at some point? Can you visually inspect the engine and see a tell tale sign of a prior top-end rebuild. I don’t think you can but if it is possible please let me know what to look for.
Thanks |
Still Doin Time
I think it would be hard to tell unless the work was done very recently. Then the signs would be obvious.
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
Unless of course a PO had been nice enough to use ARP studs which would be obvious by the rounded/nonthreaded end of the stud above the open nut
Richard Lane 1978 911SC 1973 "Clean" RS clone |
Thanks for the replies.
With the assumption that the bottom head studs would be replaced with steel during a rebuild, what about testing them with a magnet. non-magnetic = dilivar = no rebuild magnetic = steel = rebuild |
