Petronix Ignitor Install
Hi Everyone,
I did a search on this topic and found some answers that confused me. It appeared some folks recommended against following the Petronix instructions for hooking up the ignitor leads to the coil. I know little about ignitions so need some detailed help installing this trigger. I have a 75 911S. Can someone give me a "dumbed down" installation how-to please? Thanks you, Troy
Troy Past: 1975 911S Silver Anniversary-rebuilt and sublime. Past: 1988 Carrera-backdated with a 3.6 and all the goodies. Present: 2011 GMC 2500HD with the 6.0 & 4x4!, 2004 Toyota Sequoia (wife's) |
RETIRED
First throw it in a deep pond....if it floats it works......
I see those fail out of the box....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Now Mike, that doesn't help me much!
Troy
I have my pertronix hooked up to my MSD. Red wire went to the fuse block on the rear left side for power. I then hooked up the Pertronix black wire to the MSD white wire trigger . Seems to be working just fine. The pertronix is a much easier setup than the Crane optical trigger that I had before.
Old sport cars are meant to be driven 1970 911E |
RETIRED
I've got it on my 74. Same install as above. Red wire goes to fuse box in engine bay (I used the middle fuse, sport-o I believe, it wasn't being used anyway.) Black goes to the wires that normally connected to the points.
Current: 07 S4 Avant, 06 Volvo S60R Sold: '74 911, 01 986, 93 Volvo 240 |
So, In the case of my car, I have a white and a brn wire running from the coil to one of the main wiring harnesses. The coil is also grounded to the fan shroud. I have a wire going to the distributor, connected by a spade connector. It is a wire mesh shielded wire. The wire mesh is grounded to the engine (cam cover) and the interior (under the shield) wire goes toward the main wires leaving the CD etc.
What do I do with the wire connected to the distributor body and I guess the points? I obviously need more help guys. Thanks for your patience! Troy
Oh, Mike. I know there have been some negative reports about this Ignitor system. I glad to hear the contrary when it comes to this kind of stuff.
Thanks, Troy
JTO,
here is a drawing I made when I rebuilt my CDI harness and installed my pertronix. I didn't document the grounds on the shielding. The circled area is the connections with the pertronix, the other distrubiter above, is under the points config. In both cases there is a wire that goes to the main engine harness and to the CD harness. This connects to the connector on the side of the distributer with points and will connect to the black wire off the pertronix. The red wire from the pertronix connects to switched power. Does that help anymore? Just to reclarify since the drawing doesn't show it well. The black from the pertronix connects to the two wires that previously connected to the distributer (1 goes to the main harness, 1 goes to the CD harness) Last edited by Pat S; 11-16-2003 at 07:59 PM.. |
pertronix
hi
i put one in back in march? it works great. this may help
1975 911S Targa Silver Anniversary Edition |
Thanks Pat and 47silver (I forgot your name, sorry).
I think this will help me. It is just simpler than I am making it out to be I guess. Silver; I don't have a MSD unit (yet) but the original CD box. One thing that doesn't make sense yet is that I have one wire leaving the side of my distributor. It is a shielded wire. The shield is grounded to the engine and the main interior wire connects to the wiring harness. Is this the one I want to connect the Petronix black wire too? THe red wire will go to switched power ( the small fuse block where the supplemental heating fan gets its power). Thanks, Troy
JTO, I did the same install a few weeks ago. I left the shield grounded to the engine, attached red to power and black to harness just like you are thinking. Has worked fine ever since. I can attach pics if that will help. -- Bob
RAS '77 911S (sold to another Pelican) |
Hi Bob,
Thanks for the reply. Please post pics if you can! Thanks, Troy
I don't know if this will show everything you need but good luck! Again, I did the same install just the other day and was also wondering about what to do with the shield wire. A couple of members of this board helped a bunch. The shield is just an inch (in this photo) to the left of the ignition module and it goes to the engine block while the core goes to module itself (not shown here attached yet).
yes the black wire goes to the cd unit
gary
Thanks everyone. I will try to get this hooked up and see if the thing works.
troy
one more thing to add here... i've done this two or three times now and each time i forget... the nuts that hold the assembly down in the dizzy are NOT METRIC so if all you have is metric sockets, you'll have an annoying problem on your hands.
on the larger sizes, 10mm and above, you can "get away" w/ using an approximate-sized wrench, but on the small ones, one is too big, another too small... i'd have a set of sae sockets handy
dave 1973,5 |
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
