-   -   Replace Speedometer (http://forums.pelicanparts.com/porsche-911-technical-forum/268510-replace-speedometer.html)
Jesset100 02-26-2006 12:49 AM
Replace Speedometer
Even a caveman could do it:)
Donor speedo 150MPH
http://forums.pelicanparts.com/uploa...1140942542.jpg
85MPH... Get Real! To get the speedo out I went thru the trunk and used a pipe 2 feet long and pushed the speedo out.
http://forums.pelicanparts.com/uploa...1140942716.jpg
1 white/green and 2 black/blue light wires. Why? I don't know but I put it back the way I took it out.
http://forums.pelicanparts.com/uploa...1140942876.jpg
When taking the lightbulb sockets out use a small flat tip screw driver and gently pry under the socket. Don't pull on the wire.
http://forums.pelicanparts.com/uploa...1140943196.jpg
Finish 150MPH Total install time 10minutes
http://forums.pelicanparts.com/uploa...1140943349.jpg
EdT82SC 02-26-2006 01:10 AM
Wow. Your car just gained over 15,000 miles. Another option is getting the face replaced on the original speedo, and having it recalibrated to the new face. You keep the same odometer reading that way.
78P930 02-26-2006 06:11 AM
I just grab the gauges from the front and pull them out. A lot easier than poking at them with a stick.
Jesset100 02-26-2006 11:51 AM
I'm going to keep my old speedo for future reference.
I tried to pull it out but it was stuck in there. The rubber gasket was and still is doing it's job 24 years later:)
aigel 02-26-2006 11:55 AM
Nah, this being a CAVEMAN repair, you had to use a stick! :D
George
rnln 03-09-2006 07:23 PM
huh?? Our speedometer is not digital. It is mechanical and doesn't have a cable? What drives the counter?
Is the picture of the back is a speedometer or the tach meter (RPM)?
ischmitz 03-09-2006 07:46 PM
They changed to electronic at some point in 78. The transmission has a magnetic wheel and a little pickup. There is a little electric motor in the gauge that drives the odometer.
lfot 03-21-2007 01:02 PM
Sorry to bring this thread back to life a year later, but I just did this replacement job myself.
So, what is the market value of an 85mph speedometer?
