Help identify oil hose leak 911 3.2
Hi,
Can someone help identify the oil hose below (part#). It is weeping and doesn't look genuine to me. To replace do I need to lower the engine or can be done in situ?
TIA,
Oemar
Old 05-27-2017, 01:24 AM
proporsche's Avatar
Hi there
this is the line you need to get
part number is 93010734714
To replace it set your engine on top Z1. Remove the air-duck pipe then remove the distributor,Make sure you put some plug in the hole so nothing falls inside the engine and replace the line.Also get your self 2 new alu. washers for the oil through bolt.
Ivan
Make sure you install the distributor in correctly...
Old 05-27-2017, 01:39 AM
Hi Ivan,
Thank you for your quick reply. On PET I can only find 930-107-347-04, are they the same? So I need to get no 10 & 11 too?
Old 05-27-2017, 02:08 AM
proporsche's Avatar
Hi ,if you get the oil line from here or Porsche dealer it should have the end ring and nut.
The number is more likely updated to the 14....
Ivan
Old 05-27-2017, 02:16 AM
Ok thank you so much. Is it safe to continue driving the car now?
Old 05-27-2017, 02:34 AM
1988 Carrera
shadowjack1's Avatar
I would drive it. But keep an eye on it as well.
88' Carrera
79' SC gone (lost to Katrina)
75' Targa gone
72'914 gone
72' 914 gone too
Old 05-27-2017, 05:10 AM
Counterclockwise?
I'm having a hard time figuring out the location, but it looks like a vacuum line with a hose clamp on it.
Rod
1986 Carrera
2001 996TT
Old 05-29-2017, 10:18 AM
Flojo's Avatar
As proporsche said.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 05-29-2017, 10:54 AM
