-   -   Installing Bilsteins with Boge Struts (http://forums.pelicanparts.com/porsche-911-technical-forum/268944-installing-bilsteins-boge-struts.html)
Blk95993 02-28-2006 08:59 AM
May be making this more complex that this is....Just want to make sure that I am reading the instructions from Porsche 101-If I buy bilstein sports to replace the front stock Boge shocks, all I have to do disassemble the mount from the strut tower, pull the strut away from the front fender and the stock boge shock will just slide out???? What holds the bottom part of the shock to the strut? Gravity and or pressure?? Please explain/enlighten me to this design. Thanks! :confused:
Rot 911 02-28-2006 09:12 AM
Your information is correct. The strut is held in place by the strut housing cap. There is no room for it to move up and down or side to side.
http://www.pelicanparts.com/911/911_...974-75/4-2.JPG
Argeo 02-28-2006 09:35 AM
Hi Kurt,
DO you happen to have the name list that goes with those pieces?
Thanks,
Blk95993 02-28-2006 03:13 PM
Thanks for the info. The names to the parts would be very helpful. Looks pretty straight forward to me.
