Registered Cruiser
jorian's Avatar
Question Turbo Valve Covers
Anyone done the Valve cover upgrade? Is it worth it. I have an oil leak somewhere above my SSIs and I'm changing the thermostat o-ring, oil pressure light switch and the breather cover gasket.
According to our host the stock valve covers on my 87' are prone to warping. Won't these Turbo covers have the same problem over time?
87' Carmine Red Carrera - Keeper
82' Silver SC - Sold 79' Gran Prix White SC - Sold
05' Black C2S - Daily driver
I have never really completely understood anything.
Old 01-11-2005, 09:27 PM
I did the upgrade on my 74 S for the same reason. The originals were warped. IMHO it is a good upgrade. The turbo's are heavily reinforced and much less prone to warping. I found used ones that were perfect for a bargain.
Jim T.
87 911 Carrera
Guards Red Coupe
Cat Bypass, SW Chip, 7's & 9's
Old 01-11-2005, 09:33 PM
has anyone ever seen nice after market valve covers ?
tia
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-11-2005, 10:54 PM
kqw kqw is offline
I believe the '87's came stock with Turbo covers......
The Fox
Carrera
Old 01-12-2005, 07:28 AM
Friend of Warren
They do.
Kurt V
Old 01-12-2005, 07:30 AM
Senior Member
Natchamp's Avatar
How bout some trick billet ones with integrated o-rings?
Mark
The Beast
mark@hargett.com
www.HargettPrecision.com
Old 01-12-2005, 09:20 AM
safe's Avatar
Heavy stuff turbo covers, backdate to early mag covers
Magnus
Old 01-12-2005, 09:31 AM
Registered Cruiser
jorian's Avatar
My mechanic just informed me I already have Turbo v/c's. Came stock on my car.
Old 01-12-2005, 10:37 AM
Deschodt's Avatar
73.5 : Just did'em... My wrench had the engine out and he said my covers were so warped it wasn't even funny... Put new turbo covers and it's been bone dry since. They sure look cleaner too ! It's a good upgrade according to any book I've read !
Old 01-12-2005, 12:57 PM
These are available from Eagle Day. However, they're for a 993 (3.6).
Nice; and no affiliation,
Sherwood
Old 01-12-2005, 02:06 PM
Registered Cruiser
jorian's Avatar
Those are sweet.
Old 01-12-2005, 02:45 PM
echrisconnor's Avatar
With Turbo or non-turbo valve covers, you can flatten them to take the warpage out. It's a simple process with sandpaper on a flat plate. If your top VC is leaking, try this flattening approach before you go and buy new ones.
'76 911 Carrera 3.0
Old 01-12-2005, 03:04 PM
safe's Avatar
I took my upper mag covers to machine shop that milled it down 1 mm (the amount of warpage) for ~$40, a bit cheeper than new covers....
Magnus
Old 01-13-2005, 12:07 AM
SC-targa's Avatar
Did the machine shop know that they were machining magnesium? I wouldn't think they would touch it for fear of fire. We're not allowed to use magnesium in our tactical aircraft for fire safety reasons.
Jerry Kroeger
82 911SC Targa
(05 Boxster S ) gone, but not forgotten
87 Suzuki GSXR-1100
1953 MG TD Mk II
Old 01-13-2005, 05:53 AM
safe's Avatar
Jerry: Yes, I told them (him) that it probably was magnesium (I think they are original, dont know what the turbo looks like). He didnt flinch.
I dont think fire is an issue, people heat thier mag cases to remove bolts and studs and I have not seen any comments on burning parts.
Or is there a risk for disaster heating mag-parts with an open flame?
Magnus
Old 01-13-2005, 06:13 AM
Gon fix it with me hammer
svandamme's Avatar
magnesium will only ignite if it's very very fine powder ( when i wire brushed my case, i tried igniting the powder that came off it , and even that didn't work, probably because it was to contaminated )
magnesium alloy is way to dense to ignite, not even when you put an open flame to it...
Stijn Vandamme
BIMDIESELBMW116D2019
Old 01-13-2005, 06:46 AM
They also use coolant for extended milling processes. This would probably help prevent ignition as well.
Warren & Ron, may you rest in Peace.
Old 01-13-2005, 06:52 AM
svandamme's Avatar
well, i had sparks coming of my case when i was going nuts with my wirebrush... but nothing that could be considered ignition
Stijn Vandamme
Old 01-13-2005, 06:54 AM
I've been to mag engine fires. It's a pia. If a small hand line putting out 180gpm doesn't do it then the foam is used or purple-K.
Had one ignite in the owners garage. The foam had the whole house smelling like low tide. We didn't smell like roses either.
Do not under estimate mag
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-13-2005, 08:29 AM
Mine were slightly warped, so I went the silicon gasket route and it has worked so far. It hasn't been long though.
CConnor
73E targa
89 Coupe
Old 01-13-2005, 09:50 AM
