nardi steering wheel
does anyone know if a nardi steering wheel will fit on a 1971 911t? Or if I need a certain hub adapter?
Old 02-28-2006, 12:45 PM
Nobody
bob tilton's Avatar
You need the Nardi specific hub.
Bob Tilton
www.werkcrew.com
Old 02-28-2006, 01:30 PM
Hi,
I've bought a Nardi wheel for my '84 3.2, but haven't fitted it yet because I need a hub adapter and am waiting for one I've ordered to arrive. So I'm pretty sure you will need one for your '72 too.
When you order a hub adapter make sure that it will definately accommodate a Nardi wheel. The circle of 6 bolt holes required for a Nardi wheel has a different circumference to those of Momo and Sparco etc., so you need a Nardi specific adapter or one that has 12 bolt holes drilled in to accommodate different wheels (ie. a smaller circle of 6 inside a slightly larger circle of 6).
Charles
'84 911 3.2
Old 02-28-2006, 01:38 PM
GFCC
Jeff's Avatar
Also, make sure you get the adapter appropriate for your year. You will need one to fit a 65-early 74. The late 74 - 89 are longer and will put your hands too far away from your turn signal stalk, etc.
Jeff
1976 911 Coupe w/ Euro 3.0 - Sold
1987 Carrera Coupe - Sold
1999 Carrera Cabriolet - Current
Old 02-28-2006, 02:35 PM
Check with Dave , jahimiak@charterinternet for nardi wheels and hubs..
Jbrad
87 Targa
Old 02-28-2006, 03:06 PM
Whose Dave? Does he have a shop or website or something? I still need to get a Nardi horn button for my Nardi wheel.
Is that jahimiak@charterinternet.com?
Thanks.
Charles
'84 911 3.2
Old 02-28-2006, 03:50 PM
