boge shock upgrades
ok, turns out I have BOGE struts in the front and not bilstein. Are there any upgraded stiffer shocks for BOGE struts other than the OEM replacement? I heard the BOGE struts will accept a lot of different manufacturers?
Old 03-01-2006, 12:54 AM
KCinBR's Avatar
Yes, you can use different brands of shocks in Boge struts, I have Koni, and I know that Bilstein makes them to.
Check out the parts catalogue here at Pelican and you will find what you need.
KC
KC
88 Guards Red Targa (sadly sold )
2005 Boxster S
1st Porsche 73 914 (long gone)
Old 03-01-2006, 03:28 AM
Yep, Boge, Koni, Bilstein, those are your options. I used Bilstein Sports.
Old 03-01-2006, 05:15 AM
Oh Haha's Avatar
Is your car stock?
If so, then stock replacement Boge inserts might be your best bet. I just installed these in mine. I haven't been able to test drive it because I live in Michigan but I was told that they were a good setup for a nearly stock suspension like mine. Cheap, too.
Pacific Blue
Wayne
Old 03-01-2006, 05:38 AM
