One last wire, pin 7 on 79 Euro SC
I am down to only one wire left to locate. I have a 2 prong plug on the engine wiring harness. It has a blu/wht wire and a brown/ white. The blu/wht leads to pin 7 on the 14 pin connector. Since I am changing an 84 3.2 to a Euro SC I have nothing in pin 7 to receive what ever it is. I do not find a reference to it anywhere. It does not appear to be airflow. That is another pin. Any ideas.
Bryan
Old 02-17-2006, 05:54 AM
Bump
Old 02-17-2006, 10:15 AM
len911's Avatar
Just checked on a 2.7 to 3.2 wiring harness connection cheat sheet. #7 is not used. The brown-white wire is listed as the Sportomatic power source. Also lists a blue-yellow as the shift lever contact for the sporto. I would not worry about it. Good Luck! Lou
'76 911 "Moneypenny" daily driver
'74 911 "JLo" IROC DE Car
'03 CRV, '02 Jeep Grand Cherokee
'03 Holiday Rambler Admiral SE, 30ft, 8.1l, 340HP, 455Ft#
http://www.nicotra4.hpshare.net/BasketCaseMotorsports/
Old 02-17-2006, 01:51 PM
Tripster's Avatar
Send a message via AIM to Tripster
Bryan, I am starting fresh with sounds like maybe the same thing here. Any help you can provide would be great, do you have written down how you cross wired the car to motor. I have a 84 Carrera and harness and a 78 930 motor and harness. This is all I like to complete the transplant.
Old 02-28-2006, 11:38 AM
Yes but it is all hand written. Contact me off line at BDHender@comcast.net By the way the extra plug was for a Sportmatic tranny which I don't have
Bryan
Old 03-01-2006, 06:01 PM
