Dipped beam not working
I took the old girl out for a spin the other night and noticed that i only had side lights and main beam. After driving for about 30 mins the dipped beam seemed to come on all by itself......
Any ideas? Thanks. |
These cars are prone to problems with the main/dipped beam switch. There was a post in the last week or so that had pictures showing what typically fails and how to fix it. You might try doing a search on the forum.
JR |
It may be the switch in your turn signal/high beam switch on the steering column. Try a search for turn switch to get some ideas.
Check the fuse board for the dip lights.
I found the post connectors caused intermittant problem with my lights as well. |
| All times are GMT -8. The time now is 07:23 PM. |
