-   -   Decoded my options (http://forums.pelicanparts.com/porsche-911-technical-forum/269313-decoded-my-options.html)
Rad Hatter 03-02-2006 07:00 AM
Decoded my options
Keyed in the Vehicle ID info on my new '89 3.2 and hey presto came out with this lot....
Porsche Option Decoder
The following matches were found in the database. Note that you may see duplicates depending on your car's type and year. If you notice any errors please report them!
Reset and enter more codes
Code Option Description
058 Bumpers with impact absorbers
197 Higher amperage battery
243 Shorter gear shift lever
473 With spoilers
473 Power Left Seat
559 Air conditioner (with front & rear condenser)
567 Windshield green graduated tint
650 Sunroof
c15 UK package with rhd steering wheel and headlights
Paint Code L 693 Stone Grey
Interior LT (Its Black Leather)
:cool:
Jgordon 03-02-2006 08:44 AM
Nice. I have a lot of that - the short gear lever is particularly good. not a short shift kit, but I've always felt that the standard shift lever looks like a truck stick. Plus I have long arms so the short one works perfectly.
What site did you use?
RickM 03-02-2006 10:48 AM
Did you enter the VIN or the options codes into the site decoder?
S2GART 03-02-2006 11:14 AM
I too would be very interested in what website you used. It would be better than paying Porsche $100 to put it on a fancy certificate. I am REALLY interested in finding out what color my car is. The paint is original except for the hood which at somepoint was redone and the label under the trunk lid is missing. It is a factory paint job, but according to the dealer. it is not a standard color for 1983.
RickM 03-02-2006 11:44 AM
My guess is that this was used (or similar) with the option codes: http://www.kindel.com/Porsche/options.asp
Feel free to prove me wrong :)
S2GART 03-02-2006 12:46 PM
! tried putting the car's vin # in, but it didn't work.
Hatter, what site did you use?
RickM 03-02-2006 12:50 PM
You have to enter the option code and it provides a description of the option as shown in the first post.
Jgordon 03-02-2006 01:14 PM
Yeah - this isn't a kardex - it's simply a translator for the option codes. Neat nonetheless, but definitely not a peek into Porsche's archives.
Rad Hatter 03-02-2006 08:08 PM
Rick M is spot on>>>
Rick M is correct:
What you need to do is to get the options list off the VIN sticker in the owners handbook.
When I bought the car last week I was fortunate enough to be given every single document pertaining to the history of the car off its original owner (since 1989) who had fastidiously kept even the road tax certificates, every invoice and even the tire bills.
Below you will see where the numbers are listed
The VIN will NOT give you the options.
The options (out of focus) are in my instance r groupings each is 3 numbers under the Paint code LT 693 and interior LT
http://forums.pelicanparts.com/uploa...1141358455.jpg http://forums.pelicanparts.com/uploa...1141358475.jpg
http://forums.pelicanparts.com/uploa...1141358668.jpg http://forums.pelicanparts.com/uploa...1141358687.jpg http://forums.pelicanparts.com/uploa...1141358718.jpg
Cheers Richard
eyue 03-03-2006 03:07 AM
So Richard, from now on, where would you bring your car for services ?
wholberg 03-03-2006 04:29 AM
My hood sticker is gone also, but my color was a "paint to sample". When I removed the boot carpet, on the passenger side about halfway between the fron and the shock tower was a sticker that had the paint color in german. I have a Carrera, not an SC, but try looking there, you might get lucky. During a repaint, the boot was painted black, and I had to carefully remove the black from the label with laquer thinner to read it.
Rad Hatter 03-03-2006 04:46 AM
R+T
Hi mate
Road and Track...Barry
Im not paying jebsen prices they wanted 1000 USD (7000hk$) for a PPI ...crazy
Richard
eyue 03-03-2006 05:32 AM
Richard, mine has always been service by Jebsen since day one in HK, and the mechanic take care of the car very well !!!! Get some quote for parts and labor, they are quite competitive from local shop !!
Rad Hatter 03-03-2006 08:32 AM
ok good
ok good tip thanks....SmileWavy
S2GART 03-03-2006 09:20 AM
Wohlberg,
there is a metal tag under the carpet in the "trunk" It translate in English to mean "syntetic varnish". I discovered this after going to the dealer about getting the paint code/name. I too believe mine was paint to sample. These days Porsche charges something like $4,000 to do such. I wonder what it was back in '83. I'll have to go back to the dealer and have them look that number up. What color is your car? Mine is a dark red. In the garage it looks Maroon but when the sunlight hits it, it almost becomes Gaurds Red. It is not a metallic paint.
wholberg 03-03-2006 03:12 PM
Wohlberg,
My car is currently a pearl white repaint. I had known the original color of the car was a blue, and when I found the sticker and took the black paint off it said iris blue metallic (in german), which was a factory '86 color, but not an '87 color, hence the paint to sample option. If you post a good color picture of your car, I'll bet other Pelicans will be able to narrow down the color.
Good luck on figuring it out.
