3.0 with bae turbo muffler problem
Maby somebody can help me with this question. I have a 3.0 with a bae turbo kit on it in a 72 T and I have been messing with different mufflers trying to make them fit but none of them seem to want to. I fabed a plate for the turbo because the bolt pattern is different than stock turbo> Can you run strait pipe on a turbo with no muffler??? I had read somewhere that the turbo acts as a muffler some what I know it will still be load but I like it like that and what about back pressure??? Any help would be appreciated
Old 03-02-2006, 01:15 PM
Unregistered
sammyg2's Avatar
Back pressure after the turbo is unproductive and should be minimized to improve efficiency. Having said that, running a straight pipe after the turbo would be a track only modification IMO.
The turbo will muffle the exhaust note a little bit but is not a replacement for a proper muffler.
Your neighbors will thank you as well as the local law enforcment employees.
Old 03-02-2006, 01:48 PM
Thanks for the info I have been reading from the archives and got some good ideas
Old 03-02-2006, 01:53 PM
