shbop's Avatar
Help! Locked-out of the trunk.
66' 911 Can anyone tell me how to get into the trunk, now that the release cable is broken? Thank you in advance!
Jon
Old 03-02-2006, 10:00 PM
I had to take the front bumper off and unfortunately drill through the front latch panel...then pryed with a long thin screwdriver.. Mines an 81 so might be different..took a lot of work!!! Sorry I didn't take better pics.
Grusse Von Iraq.
SGT Baldwin
1981 911 SC (Slowly but surely)
1966 MG 1100 (Its worse than you could imagine)
Old 03-02-2006, 11:34 PM
shbop's Avatar
I'm crying!
Jon
Old 03-03-2006, 05:57 AM
On the long hoods you have to come up from the bottom. So you have to drill a hole in the suspension pan. But when the cable breaks it fails open. So if your cable broke and the hood is still down that means the locking shaft is stuck in the opening probably because it is off center. You should try and push the hood forward, back and each way horizontal. Sometimes you can get them to release with no drilling. Good Luck.
69 911 2.3Ez
85 928S
Old 03-03-2006, 07:41 PM
Zeke's Avatar
Every time this comes up, we all say the same things. My trick is to drive over a driveway approach at an angle, both ways. The chassis flex usually helps free the plunger.
I just used the search words "open+hood" and came up with dozens of threads. Even using those terms for thread titles only gives up plenty of reading. Good luck.
Old 03-03-2006, 08:09 PM
Rod.911S's Avatar
Not sure if this works on a '66:
'77 911S sold in 2006
'79 911SC in 2009
Saskatoon Sports Car Club http://www.ssccracing.org/
Old 03-03-2006, 09:14 PM
shbop's Avatar
Thank you Zeke, and Rod. What a great pictoral guide! I got lucky! After several attempts at creating a flat tool, it opened. Whoooow!
Jon
Old 03-03-2006, 10:21 PM
