cbrauck's Avatar
HELP, brake issues on 66 911
I have installed a new master cylinder, rear calipers, new brake lines all around, new rubber gasket for the reservoir, new pads on the front calipers but I still cannot get the brakes to pump up. I have pressurized the system with a 15lb compressor on the reservoir, vacuumed each valve on the calipers, gravity bled each valve and pump bled them too. There are no fluid leaks on the floor and I tightened each connection and used Teflon tape on the connections. What could be the issue with this?
66 Coupe 912 completely restored
Old 03-05-2006, 10:35 AM
The brake system connectors seal by metal to metal contact at the ends not on the threads. Remove all of the teflon tape. I will conjecture you have managed to cover or clog a port somehow with the teflon tape - probably at the master cylinder.
Old 03-05-2006, 10:41 AM
