Redlineshftr's Avatar
Targa harness bar...options?
I don't want to put a roll bar in my 78sc because of the extra weight and It would be overkill for me. Just looking for some added safety on fun runs. Anyone have just a harness bar in their targa? Could the Weltmeister sold by Pelican be modified to work with my targa?
Currently Porsche-less
Old 03-04-2006, 10:50 AM
HarryD's Avatar
I use the bar made by Stable Energies. Fits right in and co-exists peacefully with my stock 3 pointers.
Please note that due to the high back seats, there are some safety compromises in using a harness due to how the straps are routed and risk of slipping out of the harness. If you are planning to use a setup like mine in DE, think long and hard about a proper race seat.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 03-04-2006, 11:03 AM
Flyer88's Avatar
I use the Brey-Krause. Easy install and it has the harness guides.
Bill
87 911 Targa
06 Toyota Sequoia
Old 03-04-2006, 12:17 PM
Driver
Noah930's Avatar
Brey-Krause harness truss (as opposed to the harness bar). Needs no drilling (just bolts into existing stock seatbelt shoulder anchor points. And the shoulder belts of you new 4-/5-/6-point harness attach directly to the truss, itself.
Again, because of the sloping "shoulders" of the stock seats, there is debate on how safe it is to use a racing harness with the stock seats.
1990 Black 964 C2 Targa
Old 03-04-2006, 01:09 PM
Thanks for all the info, I just bought a fixed back seat yesterday so that part isn't an issue.
Mike
Old 03-04-2006, 02:16 PM
Flyer88's Avatar
The truss does not work on a targa.
Bill
87 911 Targa
06 Toyota Sequoia
Old 03-04-2006, 03:14 PM
Your right Bill I looked on the site and the truss is for coupe's only. Im goign to get the guide bar from Stable energies.
Old 03-04-2006, 03:23 PM
Flyer88's Avatar
You will need the H harnesses as shown above. The BK has the guides and has posts that run to the lower belt mounts for additional rigidity.
Bill
87 911 Targa
06 Toyota Sequoia
Old 03-04-2006, 03:43 PM
HarryD's Avatar
FYI, the harness I am using is a Schroth Rallye 4. It has a separation that allows me to "put it away" when I am not using it.
Harry
2020 MB E350 4Matic
Old 03-04-2006, 04:47 PM
I wonder if the bar helps reduce flex? Probably minimal because its not triangulated...
Old 03-05-2006, 12:02 AM
