-   -   What is best way to clean clad plated items? (http://forums.pelicanparts.com/porsche-911-technical-forum/269849-what-best-way-clean-clad-plated-items.html)
bigrubberjeep 03-04-2006 10:42 PM
I have tried some degraeser on some unseen clad plated parts and they seem to loose that plating, do I need to use some other form of cleaner or just dilute the degreaser some?
antares 03-04-2006 11:33 PM
Yes you are right the inorganics and strong organics will take the coating off.
I have found that simple green slightly water diluted will work fine, but do not soak it in it.
hope this helps
antares
bigrubberjeep 03-05-2006 09:58 AM
Diluted simple green huh? Thank's for the tip, I'll try that.
RickM 03-05-2006 11:08 AM
Anything more than a mild cleanser will take the plating off. Many have removed quite a bit of the hardware when detailing the engine bay area and had the whole lot replated. Not too expensive and brightens the whole assembley up quite a bit.
bigrubberjeep 03-05-2006 09:56 PM
Yeah, I've seen it. Looks real nice unfortunetly (or fortunetly)
I'm not doing any overhauls right now, it's just for those while I'm in there moments and I try to clean everything up when putting it back together.
