-   -   Restrictor (http://forums.pelicanparts.com/porsche-911-technical-forum/269904-restrictor.html)
'78 SC 10-15-2007 05:45 PM
Steve (Weiner),
I did run a leakdown test and determined there was slight leakage which was audible at the oil tank. When the oil consumption did not improve, I decided to tear the engine down and take the cylinders to a local shop (Mike Callas) to be prepped. We also confirmed the rings had not seated. The first time around, I had scrubbed the cylinders with scotchbrite; Mike honed them a bit more aggressively.
Since the rebuild last year, I don't have the smoking problem (other than an occasional puff). Don't you ever get tired of being right? ;)
RWebb 10-15-2007 06:01 PM
yes, sort of
you'll need a competent professional to perform it - esp. on a 911 motor
must be several in a town the size of San Antone...
