Bolts for Weltmeister Strut Bar
I recently purchased a used Weltmeister Strut bar but it did not come with the replacement bolts for the camber plate. Per my PET they are 10 x 20 bolts.
I figure I need longer bolts to mount the bar. Does anyone know what size and grade I need? TIA
Just a little longer - maybe. Basically the additional thickness of the WM strut mount bracket (which isn't much). The camber plate has threaded through holes so a slightly longer bolt shouldn't affect anything. To verify, remove one of the two camber plate bolts that attach the WM plate and insert a thin screwdriver blade into the opening and see how much room there is just past the last thread. Set the parking brake and block the tires so the car doesn't move. BTW, the camber plate attaches to the chassis with 3 bolts.
BTW, here's my upgraded WM with an aluminum strut bar replacing the steel one: ...and a triangulated setup with modified WM brackets: Sherwood |
Sherwood,
Thanks for the info. I figured as much. I like how you modified the Welty mounting plates. What size hole is that?
"What size hole is that?"
Harry, You mean for the strut nut? Just large enough to access the nut with an impact socket. YSSMV (Your socket size may vary, aprox. 1.25"). Sherwood |
Sherwood,
My machinist and I looked at the detail of your plate modification (photo below). Did you also machine the strut washer to fit within the hole? I ask because it looks like the washer on the top of my strut is about 2" and will not be clear of the hole you drilled, yet your picture appears to show the washer to be smaller than the hole.
Anyone have a WM aluminum strut mount for sale? I would love to get one of these.
Bill |
To be honest, I'm not sure I ever removed the washer through the new opening after the modification, but I just measured it just to be sure. The washer I have is smaller than the enlarged hole which measures 35mm ID (~1.38"). Hope this helps, Sherwood |
I can supply a replacement aluminum tube, al. rod ends and new threaded hardware, but I have yet to see a WM strut bar bracket mount made of aluminum. Sherwood |
911pcars, you have a PM
HarryD, if you need some metric hardware, let me know. It is plentyful up here and if I don't have it on hand, I can get it in a day and mail it off to you.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
I think I will have my machinist enlarge the central hole to about 1-1/2" ID and then use a washer or two between the strut brace bracket and the camber plate bars to raise the bracket over the top of the big washer. So I guess I really will need those longer bolts now. Quote:
Harry 1970 VW Sunroof Bus - "The Magic Bus" 1971 Jaguar XKE 2+2 V12 Coupe - {insert name here} 1973.5 911T Targa - "Smokey" 2020 MB E350 4Matic Last edited by HarryD; 06-01-2007 at 11:35 PM.. |
Cool, my local metric warehouse has plenty of stock if anybody needs anything..... (it is about 40,000 sq feet)
Cheers
"Ah-so.. My washer on the top is almost 2 1/2"OD.
I think I will have my machinist enlarge the central hole to about 1-1/2" ID and then use a washer or two between the strut brace bracket and the camber plate bars to raise the bracket over the top of the big washer. So I guess I really will need those longer bolts now. " Harry, Not sure if I'm missing something from my strut tower assy., but the washer I have is merely a thin lock washer for the shock insert nut (bend tab upwards against the nut flat). It appears that if you install spacers under the WM strut bracket, you might have enough room to slide the large washer under the bracket (after removing the strut) thus avoiding making the hole too large. I've seen some modified bracket holes enlarged to the point of breaching the edge, creating a C-shaped bracket and thus weakening the structure. Try to avoid this. Sherwood |
Your washer sounds non-stock to me. This what mine looks like (thanks scottb for the photo) : ![]() I quite agree that the "C" shape like this: ![]() is what I am trying to avoid (apologies to GeorgeM). I do note that he has a different camber plate setup (more like yours) then what I or scottb appear to have. Also, since the sides of these bolts will get some shear forces, I am thinking a grade 12.8 (SAE Grade 8) would be correct instead of a more typical 8.8 (SAE Grade 5) for this type of application.
Harry 1970 VW Sunroof Bus - "The Magic Bus" 1971 Jaguar XKE 2+2 V12 Coupe - {insert name here} 1973.5 911T Targa - "Smokey" 2020 MB E350 4Matic Last edited by HarryD; 06-02-2007 at 01:09 AM.. |
Harry,
If I'm not mistaken, the large cup-shaped washer isn't used. The middle of the WM bracket is shaped like the factory washer and thus used in its place. Do you have the large washer installed under your WM bracket? Sherwood |
Sherwood,
I have not yet installed the bracket. If I did a "standard" install of the Weltmeister bracket, I can see how the large washer would be replaced by the Weltmeister bracket. Since I will be removing the center of the bracket (that replaces the washer) I think I need to keep something there. I guess I could reduce the size of the washer but since it has a key to keep the strut thread from turning and I would think keeps the strut top secured to the rubber bushing in the camber plate, I think it will be a giant step backwards to replace the large washer with a smaller, standard one. I would prefer to keep the stock washer and have the Weltmeister bracket "bridge" over the washer. This would allow me to return to a 100% stock configuration.
Project complete
When I went to install it, the Weltmeister bracket interfered with the large washer on the strut. I slipped two 10 mm washers (one was too thin) between the Weltmeister bracket and the strut bracket plates to move it up a bit. The fit seems good and I used M10 x 35 (grade 12.9) cap bolts to hold the whole thing together. I will now check this off my list. Thanks to all for their support.
Harry,
Sounds good. Glad everything worked out okay. Let me know if you want to lighten the WM a little more. Sherwood |
