goldgunner's Avatar
Oil Cross Over Pipe Mounting Bracket
Because the large nut that fastens this cross over pipe to the underside of the engine will not be accessable after I mount the SSI's, I'm concerned where the (photo arrow) mounting bracket will attach and whether I have the cross over pipe aligned where it should be for that bracket mounting hole to line up.
So, any pics or descriptions where this bracket will attach?
Thanks!
Jim
1980 911SC - 2nd Rebuild in Process - 2005 Porsche Cayenne Turbo - 2013 VW R
________________________
2000 BMW X5 - 1996 BMW 530i - Toy 4 Runner (x2 or 3) - 1987 Toy Supra - 1988 Honda Si - 1984 El Camino Super Sport - MGA - MGB - Fiat 124 Spyder - Fiat 128 Wagon - 1962 Karmann Ghia - 1951 VW - 1953 Willys Jeepster w/Chevy 286 - 1995 Volvo 960 - 2006 VW GTI
Old 03-08-2006, 06:27 AM
Jim Williams's Avatar
You may have already done this, but I would check the mounting of the SSIs to see if the cross-over pipe will interfere with the Heater boxes, or vice versa. I have done a couple of these installations where even with the best possible mounting of the cross-over interfered, and I had to slighly re-engineer the shape of the SSI heater boxes with a ball-pein hammer. I think the bracket was intended to attach to the engine tin. But many of the cross-overs being supplied these days don't seem to have the bracket in much of an optimum place to directly attach it to any existing bolt. I've had to fab an intermediate bracket to attach it to the engine tin, which seemed to me to be the best place.
Hope this helps,
Jim
www.jimsbasementworkshop.com
(CIS Primer for the 911)
(73 911T (RS look) coupe)
(Misc. 911 Parts for Sale)
Old 03-08-2006, 04:30 PM
goldgunner's Avatar
thanks Jim - I appreciate your insight.
Old 03-08-2006, 05:39 PM
Gasoline User
1974carrera's Avatar
Jim,
This isn't a closeup, but if you look on the right side of my engine (left side of the pic) you can see the crossover pipe with blue tape on the end and where the fastener locates on the engine tin.
Bob V
1974 911 Carrera coupe Grand-Prix-weiß
1977 930 turbo Carrera coupe Hellgelb
2018 Cayenne turbo Schwarz
2019 911 GT3 RS Schwarz
Old 03-08-2006, 06:40 PM
Gasoline User
oops...I misfired!!!
Bob V
Old 03-08-2006, 06:41 PM
Hi Bob,
Yep, I know that's the place the bracket is supposed to attach. What I was trying to say, maybe not so clearly, is that only in one case did I have the bracket appear to be in the right place on the oil line to attach to the engine tin at the designated place. I think many of the oil lines must be now aftermarket built and not OE Porsche parts.
BTW, nice clean engine........
Jim
Old 03-08-2006, 08:27 PM
Gasoline User
Hey Jim Williams! Sorry about the ambiguity of addressing my post to Jim..I was intending Jim (Goldgunner) and his request for a pic. What you had to say was clear and good advice.
...and thanks for the kind comment!
Bob V
Old 03-08-2006, 08:41 PM
goldgunner's Avatar
I completed the installation of the cross over pipe and the SSI's this afternoon. The only position of the pipe that would permit the SSI's mounting was in the pipe's 'extreme' most position: that is with the first small bend of the pipe against the cylinder baffle tin and and the large curve essentially resting against the utmost end of the block.
In that position, the SSI's would both mount well.
I expect, as Jim Williams noted, to have to wrestle the J-pipe mounting bracket to it's place on the tin...that is, when i get the top stuff on: shroud yet to be delivered, tin, manifolds, etc.
Thanks All!
Old 03-08-2006, 09:10 PM
