3.2 Swap wiring Questions. It's in but won't start.
Lee and Jeff live too far from me to come over daily and bang on me to ge this finished.
Well, I have gotten the engine cranking but it wont start. No Spark. I borrowed a known good coil from Jeff and have 12v there. I have swapped the Reference and Speed connectors, just in case. Going through the wiring, I think there may be some incorrect connections. From the DME going forward there are 8 wires. The ones I certain of are a black/violet (tach), red (battery) and red/green (fuel pump). There are two 20 gauge wires cut short that I think go to the A/C and are green/yellow and black. These are not used. A larger black wire is for the coil but Im not sure which fuse connection is suitable. Switched and cranking 12v.?? Finally, a yellow and a black/grey that are spliced together into a yellow. When I put this one to 12v, I hear the DME Relay actuate. Im sure this one needs to be a switched 12v but not sure where to put it or if the black should be with it. I've cranked with the yellow on a constant 12v and with the coil on a constant or switched 12v. No joy. Another thing is the 14 pin harness. I was able to mostly decipher the 72 14 pin harness and ID the wires but the 14 pin plug on the 88 engine is a sticking point for me. My neighbor just got and 87 Carrera and I pulled his plug and the wire colors match my 88. I think I need to pull out the (as per Marc's page) #2 and #8 on the engine side and tape them back. Any other changes here? My 72 1 yellow, AUX Starting relay E&S 2 green, Oil Temp SW 3 green/black, Oil Temp Indicator 4 green/red, Oil Press Ind. 5 green/yellow, Backup light 6 grey, Backup light 7 red/black, ?? 8 grey/red, speed switch(MFI) 9 black/violet, Tach? 10 VACANT 11 blue, Alternator 12 VACANT 13 yellow/black, Governor ?? 14 red, fuse box III My 88 Engine 1 yellow 2 red 3 green/black 4 green/red 5 green/yellow 6 grey/brown 7 VACANT 8 brown/black 9 green/white 10 VACANT 11 blue 12 VACANT 13 yellow/black 14 red Any insight from you guys?? |
I think black on the DME lead needs to go to switched power at the fuse box.
Also, check this link made by Jim Hamilton: http://www.addictionmotorsports.com/WiringHarness.htm |
Earlier I pulled back the black tape on the wiring harness that goes to the trunk and found the red/green (fuel pump) wire spliced into a solid green wire. I was told green was the A/C wire and since I don't have A/C, I left it unconnected. We wired the fuel pump directly to a switched supply bypassing the DME. I went by Patrick Motorsports and discussed this with Jim. Turns out I have to go through the DME as the 12v for fuel pump also enables the ignition circuit.
I think I have that squared away now but still wonder if I still need to make changes at the 14 pin harness. Oh, I'm using fuses 7 and 8 for switched 12v going to the Yellow wire and black wire. Will that be ok? |
I don't know. I thought the yellow wire was tied to the starter solenoid signal?
I believe changes would be necessary at the 14 pin connector. That part is spelled out quite clearly by the link provided. Doug |
After speaking with Jim Patrick, I have put the 8 wires from the DME going forward in the following locations. However, it still won't start.
The small black and small green/yellow that are cut short are for A/C and not used. Yellow and another small black are spliced together. It's a solid yellow forward and from pin 5 of DME and go to fuse 8 "turn signal and back up light". Large black is from the coil and also goes to fuse 8. Violet is for the Tach. Red/green becomes a green and is for the fuel pump. It goes to fuse 3. Nothing else is on this fuse. Red is from the DME relay pin 6 and it goes straight to battery. http://forums.pelicanparts.com/uploa...1141836748.jpg Another thing. My fuel pump runs as soon as I turn the key on. I didn't think it would till I went to startup. :confused: The pump runs during cranking. I have a spare DME relay and coil and have tried many different combinations including swapping the reference connector with the speed sensor connector. It still won't fire.:( |
Well, I'm glad to see you got a clicking DME, and a running fuel pump. When we spoke on the phone, it sounded like that would be the problem.
Now I would check grounds. Next, see if you can borrow someone's DME brain. (Actually it would be smarter to swap your brain into their car to see if it runs. Swapping theirs into yours is riskier, since there is the potential of frying their brain if there is a problem with your wiring) I suppose maybe if the tach wiring were funky, it could kill the coil signal. But the 14 pin connector really shouldn't prevent it from getting spark. It would just prevent the gauges from working, alt. from charging, and the starter from cranking potentially. |
I have the Violet going to the #2 pin on the tach and the (+) to #5 and (-) to #6. I would have to pull the steering wheel off again to check that but it may be worth it.:(
can you check that you are getting power to the coil when the ignitiion key is on? Are you getting spark when cranking?
It does seem strange that the fuel pump runs with the key on all the time. It should turn on for half a second, then stop. Then start pumping again once the engine cranks. Have you checked for spark and injector pulse since you got the DME relay working? Is the 4-pin connector behind the motor plugged in? |
Next, is the fuel pump pumping fuel? AND have you done a volume test on it to test it? Doug |
Don,
if you do a search on my name you should find alot of what you are looking for as I just went thru alot of wiring of my 84 Carrera. if you dont find what your looking for PM me and I will give you info I have found elsewhere not posted on this forum. Mark |
I'm not sure I can help but I'm going through the same thing. My harness had the dme relay plug cut out with a few other wires. Here is what I have.
grn/yel is for A/C going to pin29 yel is ignition switch going to pin 4 2 blk -both on mine tested out to pins 21 and 11 for tach. The large blk goes from coil to fuse 8 and out of fuse 8 to pin 86 on the dme relay. The large grn goes from the coil to pin 1. The red/grn goes from the dme relay pin 87b to fuse 3 and out of fuse 3 as a red to the fuel pump. The other side of the fuel pump is brn and goes to the carrier plate ground screw. Pin 30 on the dme relay is red and goes to the battery. Make sure like Tyson and Doug said you have spark and the 4 pin connector behind the engine is plugged in. Good luck I'll be were you are in a few weeks. |
Which side of the fuse panel should I make the connections? Right or left. Remember, my car is a '72 and the panel is mounted vertical. Marc's page refers to a '77 panel and its horizontal. |
Here's something interesting.
Key on, my turn signals do not work at all. Key off, they come on but no blink. No brake lights at all. hmmm, the thought plickens!:confused: |
Re: 3.2 Swap wiring Questions. It's in but won't start.
Also, did you keep your relay panel? Or did you just hook the engine wiring harness to the main chassis harness? heres the 3.2 from Marqesqs site Quote:
Good stuff. Sherman, I never messed w/sensors. Just the connectors over left intake. Its a good thing to chk tho.
I really think the problem is within the 14 pin conn. Doug, the pinout doesn't specify how he made those work. Move which wires to where? Looks like his harness just jumpers. I'll look at it more. |
Here's how I was going to map my chassis wiring harness to the engine wiring harness on my 3.2.
http://forums.pelicanparts.com/uploa...1141879398.jpg Most of the pins are already aligned. I was planning to change engine harness over to a 14 pin male connector, move pin 9 to slot 2, and then tie off the wires that would normally be in pins 2, 7, 8, 10, 12, 13. After that id just plug the engine harness into the unmodified chassis harness and put the relay panel in a box for safe keeping. Where did you put the red fuel pump relay? I have a 5 pin relay socket in my engine bay from the DME harness thats confusing me. It can only be for a fuel pump relay, but I would have thought it would have been in the front of a carrera :confused: |
He made a conversion harness which adapts one set to the other. You can move the pins around to suit, too. Doug |
| All times are GMT -8. The time now is 03:20 AM. |
