I was quoted $160 for the alignment w/o corner balance by a shop in NJ listed in Bruce's book. With sales tax, that should come out to about $300, right? I love this state.
:mad: Chris |
So to summarize your method:
You decide to measure the floor from the left wheel to the right wheel and get a reading of 5 degrees slope. You then check for camber at the left wheel and see 3 degrees. So, you got negative 2 degrees of camber at that wheel. OK. Using the same sequence you progress to the right wheel using the smart tool and again factor in the slope. No problem.. You now have your right wheel camber. But - my garage slopes in from ALL sides inward in order to drain toward center. Most garages do this I think. The angle each tire sits on the concrete is slightly different for each wheel even though yes, there is a general slope from left to right. Sweating out the small stuff can be a burden. The 'peace of mind' of a professional alignment is what folks are able to have when spending $400. Phil ______________ '74 fiat 128 '80 928 '82 Targa - sold |
My garage floor slopes towards the driveway. No drain. But if I had a floor like you have I would do it in my driveway....
I would rather have a professional do it cause I know me and I would spend probably 2 days doing it and it still wouldn't be right and I would have to take it somewhere and I would get charged even more. |
My garage slopes only towards the door, away from the house, at about 1 degree, so it has been very repeatable for me. Your results may vary. As I said in an earlier post, my mechanic allowed me the full use of his alignment rack, under his supervision to perform a full alignment. Since that time, I have only checked and made small adjustments in my garage, but my measurements have been consistent. I don't recommend my DIY method as a final setting, but it is accurate enough to get you on the road. It's major flaw is the absence of a caster method of measurement. If you are not careful when adjusting camber, you will affect caster, which can't easily be measured on a garage floor. |
Edward |
Zoanas, I'm currently dealing with a point you raise about caster, and this board is terrific for help on this stuff. http://www.pelicanparts.com/support/smileys/wat2.gif I currently am having a problem with my 928 in that one wheel needs to go the max amount of travel of camber to get me on the road. Just that one side. So, the caster is then compromised - or at least, much different than the other side. I don't know how to solve it , but I sure as hek wish I had a reference point to measure and compare the left side caster to right side caster. Phil _____________ '74 fiat 128 '80 928 '82 Targa - sold |
Link to manual.pdf There is a way to measure caster by turning the wheel 20 degrees left and right and measuring camber. Then there is a formula to determine the caster for that wheel. |
Update: I've adjusted my ride height and had my wheels done and ordered my tires. I should have the tires on the rims, strut brace in and bump steer kit all installed this week. Now, I JUST scheduled an alignment with the stealer (dealer) and I guess it depends on who you talk to over there cause now I got a different quote from a third guy of $220.00 over the phone. I got his name, so they can't wiggle their way out of this quote, and set up my appointment with their guy that's most familiar with '80s 911s. My 930 should be back on the road by the middle of next week if all goes well.
$200 for four corners alignment is reasonable.
geez, 200-220 is really cheap. In Chicago its absurd, some shops charge like $1,000. I called some here in Phoenix and got skyhigh quotes as well.
After noticing excessive wear on the inside tread of the left front tire I called around to get prices for alignments. The first quote (from a shop wih an excellent reputation for Porsche work in the Baltimore area-Ralph's) doesn't do alignments but offered to make an appointment at a shop co-located with his...price was about $120. I called anothe foreign car shop closer to me and received the all too typical "we won't know until we dig ito the front end, could require the replecament of many parts, but we won't know until we spend about 4 hours on the job...4 hours at about $80 per ($320). I then called a third shop with whom I had dealt on my ther cars (Federal Motors in South Baltimore). Chris quoted $69 for a 4 wheel alignment. That was about a month ago; the difference, after the alignment, is definitely noticeable
I ended up paying just shy of $350 but it included a corner balance.
Now you should set up a home alignment setup and take reference readings for future changes.
hey Zoanas,
your avie's getting old, how bout giving us all a new set of 38DD gunbolts to gawk at huh? |
How about EE's?
haha your too much, you must have been breastfed until last week or something:)
Actually, I'm still on the "bottle". Should be breastfeeding tonight. :)
Guys, I just had the 930 re-aligned for $150, but it turned out to be a very dissapointed deal. First, the car now pulls to the left. The underbody - right on front of both rear sway bar mounts - got smashed/dent/pushed in with some of the undercoat riped obviously done by jacking the car on the WRONG place - it appears to me that it slipped off the jack and hit something??? Also, one of the rear toe adjustment nuts is now almost round due to the force they applied with the WRONG tool. What would you do?
An expensive alignment with worn out suspension components may not produce the magic band-aid.
If the sloppy bushings allow the tires to move out of toe, or one t-bar/shock is flat, then the static settings won't help much under real driving conditions. For the price of two or so alignments, why not get the Smartracing/other products that can be used on any car for a lifetime and then re-sold? Mark the strut/shock tower first so you know how far your changing things. I had a 4-wheel alignment from a shop recommended by a Porsche builder (grrr-G.D.Racing in Bay Area), and on the freeway home the rear wanted to bounce between the adjacent lanes. The computerized readings showed all wheels were within specs. It took an argument to get his kids to re-do it, and I watched as one showed the other how to use a torque wrench and the clutch felt funny afterwards his "test drive". The ending ride feel was worse than the initial. |
Front toe is easy, but working with the eccentrics adjusters on the rear is usually not something most alignment "gurus" at the chain stores know anything about. This is not to say that there are no good shops out there, but most don't have a clue when it comes to P-cars and their adjustment systems. |
When (if ever) I manage to install the new turbo tie rods, the toe-in will need a check up.
Donīt wanna sound cheap - but wouldnīt a front wheel alignment suffice ? Basically just checking toe-in ? |
All Ican tell you is it's not easy to do. Even the front takes along time. Helped the technican do mine and we took five hours and everytime you move something something else changes. My car was really off though. After doing this I don't see how you could do an alignment at home with string.
I go to a local tire & alignment place (NTW) and have a certain guy I've vetted do my alignments. The way I see it, you can pay a place that really knows Porsches to align it or you can find some guy that aligns cars all day long and sit with him while he aligns your car. I did this a couple of times until I was satisfied that he cared. (Then tip him well.)
-Chris |
I tipped him well, he broke a sweat and was worried it would take him all day. So I put on some gloves and went out there to help him. Thank god the shop is a bunch of motor heads. they didn't mind and I had to show him where all the adjusters where located and everything went fine. Also becasue I was right there looking at what he was getting I could see how close he could actually get to what I wanted. To do an alginment on these cars it takes atleast two people working on it. Could also have had to do with me replacing all the rubbers and that things where way off!
| All times are GMT -8. The time now is 04:12 PM. |
