POP QUIZ! Name that part!
What is it? I can't firgure out what is that red capped thingis... It's on the rear part of my 77 3.0 engine, just above the clutch, under the air box. Should I replace it since I am here? Brown / white wire.
http://forums.pelicanparts.com/uploa...1141953073.jpg |
oil pressure warning light sensor. Its cheap and it will fail at some point.
Yes replace it, its an oil pressure switch and while you are there replace the O ring on the internal oil thermostat, its the oval shaped flange with 2 nuts just behind the "red thing" in your picture.:)
Thank you so much guys... I was pulling my hair out.
Thank you! |
| All times are GMT -8. The time now is 12:25 AM. |
