Executing the proper burnout
Boy, these things sure have a lot of power and torque, but I can't seem to execute the proper burnout procedure as easily as I could in my old powerglide Chevelle - the Carrera seems to want to jerk and wheel hop all over. What's the best technique? Which gear? How bad is this for the drivetrain?
The best technique is to not do it. 911's are designed to hook-up and launch as a result of the rear weight bias. It's what propels them out of the corners so fast. If you want to do burn-outs, get something with a big heavy engine in front and a light rear-end -- like a Chevelle!!!
What the Heck....
go buy a corvette |
6000 rpms - then drop the clutch - 1st gear. What year?
Just grow a pair and FLOOR IT!
'85 Carrera coupe. If I lived in Florida I'd go topless, too.
Corvette - UGH! I don't like cresting hills blindly.
Try a dirt road
They are around 1500 -2000 to rebuild - Take it to a racetrack with curves instead. You will be happy, and your car will be happier. |
bring money
Would you smack your wife\GF around just for the fun of it?
ianc |
maybe just a gentle tug of the hair at the appropriate moment
ianc |
Son,
I learned the hard way about treating a 911 like a Chevelle, Camaro, etc. $2000.00 in tranny parts later I have a rebuilt gearbox and a pretty pi$$ed off wife. Resist the urge to do it. My SC has enough torque to get off the line pretty quick WITHOUT dropping the clutch. |
I peel out in my C4S all the time. It'll burn all foe tires.
If you're gonna do it, post pictures!
Well, since no one else will tell you , it falls to me to let you in on the secret. Bacon fat !!!! Coat the rear treads and you'll smoke em every time!! Smells great too !!!!
Burnout like this:
http://forums.pelicanparts.com/uploa...1142050560.jpg Leads to Porsche like this: http://forums.pelicanparts.com/uploads7/11142050585.jpg ;) |
you mean if I do a burnout in an old datsun it'll turn into a new Porsche Turbo, COOL!
Place rear tires in water...
Select 2nd gear... Pre load rear end.. (hand brake up and feather clutch to remove R/P gear lash) Hand brake down. rev 3k release clutch and hold at 4500rpm. As car rolls forward clutch it before the rear tires hook. This avoids shocking the rear end and busted R/P, CVs, axles, stub axles and axle splines or hubs. Thats how the VW drag racers with fragile transaxles and a couple hundred hp do it. The Porsche was designed for things much greater than burn outs.;) Can't help you with wheelies. http://forums.pelicanparts.com/uploa...1142056208.jpg |
I'm wondering how a 930 tranny would hold up to repeated burnouts.
It is hard to resist lighting them up every now and again. To avoid torquing the tranny too much, I like to roll my way into a smoking donut.
I've seen some pretty cool donuts done in a 911, just not planed.
do it like this: http://www.dailymotion.com/tag/auto/video/61901
Geez, part of the fun of horesepower is burnouts every now and again. Just be sure to preload the running gear as another poster mentioned, you're pretty safe in 1st if you're just looking for a little smoke and tail-hang on launch in a pre-G50. Hold the handbrake, little load on the clutch, rev her up and let the rest of that clutch go as your right foot goes to the floor.
It's a trick with a 915 tranny, takes practice. The G50-50 930 I'm running now is a little...er...easier... You CAN'T burnout a 911 if you're afraid of breaking it... |
| All times are GMT -8. The time now is 02:23 AM. |
