-   -   Making progress on my 3.4 twin plug conversion (http://forums.pelicanparts.com/porsche-911-technical-forum/270891-making-progress-my-3-4-twin-plug-conversion.html)
syncroid 03-10-2006 05:54 PM
Well I am getting pretty close. I got my sheet metal back from the powder coaters today. Its going to be hard to wait for that splitter. <img src="../../ultimate/biggrin.gif" border="0" alt=""><br />
<img src="http://forums.pelicanparts.com/uploads7/DSC063331142041083.jpg" border="0" alt=""> <img src="http://forums.pelicanparts.com/uploads7/DSC063341142041109.jpg" border="0" alt=""> <img src="http://forums.pelicanparts.com/uploads7/DSC063351142041142.jpg" border="0" alt=""> <img src="http://forums.pelicanparts.com/uploads7/DSC063361142041168.jpg" border="0" alt=""> <img src="http://forums.pelicanparts.com/uploads7/DSC063371142041187.jpg" border="0" alt=""> <img src="http://forums.pelicanparts.com/uploads7/DSC063381142041209.jpg" border="0" alt=""></font>
WydRyd 03-10-2006 06:30 PM
WOW, awesome :)
Why don't you just hook up two MSD 6A's and a pair of Blaster coils?
No need for the Andial Splitter.
Fast951 03-10-2006 06:45 PM
If you are running the Motronic, we just released a wasted spark setup (no distributor needed) that works with the Motronic system. Plug-and-play setup, no additional hardware except the electronic we provide.. It supports single and twin plugs setup..
WydRyd 03-10-2006 07:11 PM
How much is this, Fast951?
Carrera3.5L 03-10-2006 08:59 PM
Stick with the Andial Splitter and the additional Bosch coil. The final product will be an OEM quality look & install.;)
Your motor (other than the distributor which to many smog techs looks original anyway) looks bone stock, that much easier to pass the visual test when going through a CA smog check.:)
BTDT.;)
Just consider losing the heat exchangers/catalyst for the other 23 1/2 months, as these will restrict power. Depending on what other mods you have done, a 3.4L twin-plug with stock heat exchangers/catalyst will make 250-260 horsepower on an engine dyno. We built these all the time at Andial using 964 cams, modified intake plenums & a Tezet sport muffler.
Looking good, hope its running soon.:)
Ralph
syncroid 03-10-2006 09:39 PM
BTDT.;)
Ralph
Yes I will wait for the Andial splitter to become available. I looked into the MSD setup and did not like the whole "non factory" look. I like the under stated sleeper look. I'm not against the MSD setup one bit. Its just not for me!
Every car I have ever put together has had that "wait a sec...is that stock, or is it not look". That is the effect I am after. I'll be driving this car daily when its done. I want it to be as legit as possible with the California smog laws. I think the referees would even agree on this one. It should run cleaner out the tail pipe now then when originally equipt.
I need to fabricate a stainless heat sheild between the cat and the lower 1-3 plug wires still. Ideas welcome. SmileWavy
Fast951 I am interested in hearing more about your set up on the wasted spark set up. Tell us more!
